> 440 Li Ignition Barrel, not working
zork
post Apr 12 2005, 11:35 AM
Drives: volvo 440 li 1.6 1992
step 1 key barrel removed able to start car with pliers
step 2 replaced barrel (new) car does not start
step 3 removed barrel used pliers car starts!
step 4 ordered steering column complete with lock and barrel!
step 5 fitted steering column still the same problem
step 6 removed entire contact unit left hand side of lock and am able to start car using a screwdriver!
every time i put a key barrel in new or old it is the same problem car no start!!!!
help me please, i cannot see why there is any logical reason why the car will not start with the key and barrel fitted!!! Can anyone else think what it maybe!
post Apr 12 2005, 01:59 PM
When you have the switch out can you see the rod moving that turns the electrical part of the switch?
Something might not be matching up properly.
zork
post Apr 12 2005, 03:21 PM
yeh it seems to be moving ok. really am baffled by this one!
The barrel can only be reinserted in position 2 and the switch end can only fit in one position: Maybe I should try a new switch!!
post Apr 12 2005, 06:10 PM
That was where I was going to go next.
zork
post Apr 13 2005, 12:55 AM
thing is when the key is turned to position 2 the electrics come on as expected but if i try to turn it over the engine will not start- very wierd and twilight zone stuff!
tom_veale
post Apr 13 2005, 03:21 AM
Drives: Volvo 440
i had a similar problem with my 440 - all the lights come on, but when you try to start to car they don't dim, and nothing happens. it turned out to be the starter motor on mine, but before i replaced this, i tested the igintion barrel by connecting the two terminals for the starter motor with a push button.
hope that helps
zork
post Apr 13 2005, 12:26 PM
cheers for the tip, i will attempt this befor attacking the car with a branch and replacing the starter motor! :thumbsup:
zork
post Apr 14 2005, 11:38 AM
Just got it sorted, it was the switch :unsure:
Thanks for all the help and tips, i cannot believe we went to such extremes,
still i now know what to do in the future!
QUOTE
A CAR DEFINED - heaven when working- hell when not!
post Apr 14 2005, 01:19 PM
IM glad you got it running.
Thanks for posting the update.
Bundolo
post May 9 2005, 07:48 PM
Drives: Volvo 440 dl
well,same thing happened this evening to me,tommorow morning iŽll try same procedure...just a question to Zork: when you turned the key in position 3(starting position) did lights on board went out as well as the road lights? cause,if they did go off then i got exactly the same problem.....and when key got released all went on again...if so,thank you guys cause i think its the same problem...
tom_veale
post May 11 2005, 04:25 AM
Drives: Volvo 440
if the lights are dimming then it usually means that there isnt enough power in the battery to turn the starter motor - could be a poor battery, or alternator, or even a bad starter motor....
Bundolo
post May 16 2005, 09:54 AM
it was a starter motor,i took it off,cleaned,changed brushes and it works now,thanks for the tips...
biken
post Jan 28 2006, 01:28 PM
Drives: Volvo 460
I think I'm experiencing the same problem.
The problem comes and goes. I can move the ingition key and go from shift 0 to 1 and the fan, stereo and lights works as i should. But when moving the key to shift 2 and trying to start the car nothing happens.
All lights go out prioritizing the starter motor. But there's no click at all. No solenoid or relay clicks. Just silence.
Then I leave it as it is and sometimes after an hour or sometimes after a couple of days it starts again. And I can hear a click this time.
I know its either the ignition barrel, solenoid or stater motor.
My question to you is how to remove the starter motor? It is located very uncomfortable behind the engine. Not reachable from either above or below.
Do I need to move a lot of stuff do reach the starter motor? Or do I need to lengthen my arms?
My idea is that either the cable from battery that is not properly connected or that the ground cable is damaged. At least I have to try cleaning the starter motor. I did that on an Audi and it worked that time.
Regards
Biken
Black Beauty T4
post Jan 29 2006, 02:27 PM
Sounds like either a poor electrical/earth connection, an intermittent solenoid fault or a knackered starter - would suggest checks are done in that order.
I replaced the starter on a '94 440 1.8Li by driving the front wheels onto ramps & after disconnecting the battery, removed the air cleaner assembly & some other bits to improve access. It was a while ago, but from memory I might have had to get to one mounting bolt from below the car & one from above, standing on a box - brain not what it used to be but I can remember that it was quite awkward!
Good luck.
BB
:thumbsup:
No New Posts Ignition Switch, Abs Light And Shift Lock Button
1 reneedalady 12 20th November 2008 - 08:23 AM
Last post by: ampangbear2
No New Posts 440 Non Starter
15 440 bloke 116 14th November 2008 - 04:19 PM
Last post by: 440 bloke
No New Posts 440 Heater
1 wellskint 13 13th November 2008 - 02:30 PM
Last post by: grendel1960
0 angusjustice 23 12th November 2008 - 03:09 PM
Last post by: angusjustice
No New Posts Topic has attachmentsIgnition Key Question
1 bluehills240 60 4th November 2008 - 09:56 AM
Last post by: robert240
Time is now: 22nd November 2008 - 01:29 PM
