> 79 244 Wiper Problem & Od Problem, 2 Issues
PolishX
post Jul 13 2008, 10:48 PM
Drives: 1979 Volvo 244
#1.) My drivers side wiper stopped moving , I can hear it spinning and the pass side works fine just not the drivers , how do I fix this
#2) My OD doesnt work , I pulled the insert for the glovebox and there is no relay that I can see ... any suggestions where it may be ?
#3) there is a rubber hose that is suppose to be connected someplace I have attached a picture of the engine you can see the hose .
PolishX
post Jul 14 2008, 01:27 AM
I pulled it apart again took the stereo out etc. no relay . so I OHMd the switch , the swith was bad , I hit the new button to test it I hear a relay click on the drivers side of the dash and the OD switch on the dash lights up ? VERY ODD . Also I see the switch listed on the 81 and up models but rarely on the manual 79 version I have . Ordering up new knob and switch , wish I could router out a generic and be done with it
post Jul 14 2008, 05:58 AM
Drivers wiper: is the mounting nut on the arm loose/does the pivot shaft turn? or is the linkage at fault?
OD- if od light is on, then NO OD. Relays known trouble spot, also corroded fuse/holder (11?) and bad/dirty wiring and bad solenoid (that one's $$$) If you NEVER intend to tow/carry full loads then a bypass plate is available in USA for abt $35-. Google. Relay is behind center console in dash, on the right I believe, and has 5 terminals. It's usually white. It can be substituted with an ordinary 4 pin relay and a bi-stable flip-flop made from a 555 timer chip, if you can find an electronics friend to make it up. <$5- + the relay. OEM relay can be dismantled and resoldered, sometimes that's enough. Not a job for amateurs. Good electronics soldering takes training & knowledge-it is a 'learned art'. Also, check tranny fluid-if old/dark-suspect not often chaged-could be damaged internal filter/sludge blocking things-recommend change tranny oil and filter-now, and at service intervals. Lots of grief on this reported here. Tranny fluid usually very specific-follow instructions to avoid $$$$ down the drain.
Hose-look for the other end hanging around. It took full manifold vacuum-there aren't too many things that need that in such a large size. Perhaps an actuator, a sensor, or electric-vacuum brakes (trailer?). Make sure it doesn't leak!!!!!! does it go to your crankcase ventilation system????? Underneath the manifold???
PolishX
post Jul 14 2008, 08:13 AM
well thats odd . before i swapped the swith for a temp one to test it the OD light never came on . temp switch it came on fine like the manual says it suppose to .
Wiper . the arm from the drivers side moves but just not the shaft that is connected to the drivers side arm .
I am replacing the flame arrestor today the old one doesnt look well .
post Jul 14 2008, 10:10 AM
Switch is MOMENTARY ON function, press once to set, once more to reset, again to set ad infinitum. New switch may well make it work, if the old one was bad or had bad wiring-not unknown. OEM switch is more rugged than most commercial stuff I've seen. You could use a plain relay and a lock on lock off switch, but they'll wear badly with the high useage. OD will engage on flat, modest throttle abt 70kph (~45mph). I know nothing about the operation of a manual gearbox. I doubt it will be selected until you are in 4th, and then it may require a clutch operation to allow it to change up or down. READ THE OWNERS' MANUAL for correct technique. google for a download?
Sounds like your wiper pushrod is popped out or has a broken bushing, you'll need to take it further apart. It is remotely possible that if it had been iced up enough, it may have sheared off some internal part if switched on.
the flame trap connects (on mine) to the oil trap below and the air intake pre-butterfly above. Other motors I have seen have gone directly from engine breather to manifold vacuum via a PCV w & w/o flame traps.
1994 940 wont start
3 tberiau 29 17th November 2008 - 04:00 AM
Last post by: alon
No New Posts 244 Fuse Box Location.
1 Hananb 35 5th November 2008 - 09:41 AM
Last post by: robert240
No New Posts Odometer Accuracy
Anybody check theirs?
8 rosso75 88 1st November 2008 - 11:46 PM
Last post by: rosso75
No New Posts Problem With Newly Bought 850 Turbo!
Anyone help me diagnose this problem?
9 dmtri07 221 24th October 2008 - 11:47 PM
Last post by: swedseed850
No New Posts Wiper Motor Seal
or, do I have to do this all over?
3 forty2 127 19th October 2008 - 08:44 PM
Last post by: forty2
Time is now: 22nd November 2008 - 01:04 PM
