> Unidentified Squealing (probably Not Brakes), Strange squeal coming from rear
sun_q
post Jul 12 2008, 06:36 PM
Drives: 1993 Volvo 850
Hi all,
Many thanks for anyone who can answer this question:
There's a squeal coming from the rear of my '93 850 (175K), near one of the rotors. However, the squeal persists even when the car is *stopped* and idling. Furthermore, if I turn the car off and then turn on *only* the electrical, the squealing returns for about 15 seconds. I know the rear rotors and e-brake need to be changed, but the above symptoms suggest another problem. Oh, it's 90 degrees out and I did get the beast up to 105mph just to see...
Thanks in advance!
xpiecemealx
post Jul 12 2008, 08:38 PM
Any chance its coming from in the trunk? It could possibly be your fuel filter but I don't know what else is back there that could make such a noise being a 93 owner myself. This is tricky if its coming from the rear end, theres not much back there to make noise if its not the brakes.
post Jul 13 2008, 01:59 AM
QUOTE(sun_q @ Jul 13 2008, 07:36 AM)
Hi all,
Thanks in advance!
[right][snapback]86258[/snapback][/right]
Thanks for the description, at least we can zero that down to just the electrical stuff.
What about the fuel pump?
blakbyrd
post Jul 13 2008, 02:36 AM
Was going to suggest the fuel pump as well, as it should be located in the rear (passenger side I believe). If it goes away after a few seconds when you turn the electricals on only, then it would make sense. When you first turn the electricals on the fuel pump will turn on to provide the fuel pressure in the lines before y ou start the car. Once the pressure is obtained and no fuel is yet being used it should cut off. If it lasts for quite awhile then its possible your fuel pump is going bad and isnt pumping as quickly as it should or unable to build up pressure as quickly as it should.
If that is the case then it would probably be one of:
- bearing going out in the pump
- impeller in the pump is worn out or loose
- trash in the tank is stuck in the pump
Just my guess on the problem, but there isnt much more back there to make noise that is electric. I dont know for certain about the suspension though. You can probably determine if it is the pump by having someone under the car by the fuel tank when you put the car into the On position, as they may be able to better pinpoint where the sound is coming from.
For those who would know, does the TRACs system have anything to do with controlling/correcting the suspension? Some carscan/will do this but I am not sure about Volvo (my previous Subaru did, and would even let me raise/lower the car about 4 inche as an OEM option).
Good luck. Let us know what it was if you figure it out.
xpiecemealx
post Jul 13 2008, 09:13 PM
Minor slip of words. I meant fuel pump. oops. :beer:
No New Posts Pinned: Topic has attachmentsSquealing Brakes
...before you start replacing anything..
10 ampangbear 178 20th November 2008 - 01:02 AM
Last post by: ampangbear2
5 elmwoodblues 25 18th November 2008 - 09:56 PM
Last post by: elmwoodblues
No New Posts Brakes And Vacuum
Related??????
1 sargesvs 77 14th October 2008 - 05:44 PM
Last post by: robert240
No New Posts Not Sure If This Is Normal.
4 schaffee 90 4th October 2008 - 09:36 PM
Last post by: schaffee
No New Posts Brakes
brake locking
2 james thomas 32 9th September 2008 - 09:54 PM
Time is now: 22nd November 2008 - 12:04 PM
