> Front Pass Squek, Can't figure it out
rbodor
post Jul 8 2008, 10:23 AM
Drives: 2001 Volvo S60 2.4T
So I have recently replaced the front suspension control arm bushings (4) and in the process broke the driver's side CV boot but had it replaced with no problems.
Only a couple of days after getting the CV replaced I noticed some noise coming from the passenger side. It sounds like its coming from somewhere close to that front wheel. At first it sounded to me a lot like metal clanging against metal - a thick "THUD" with a bright metallic sound. It vibrated throughout the car whenever I went over any bump (or any sort of unevenness on the road going 35mph+) so I figured it had to be two pretty big pieces of metal hitting.
I got under the car and decided to replace the front control arm rear bushing nuts and bolts (one was bent and they needed to be replaced). I replaced with same size nuts and bolts with washers and lock washer, figuring the sound was made by the bolt clanging up against the front suspension. But the sound stayed.
I looked at the control arms and thought maybe when replacing the bushing I didn't push it in far enough and the control arm was clanging against the suspension on the passenger side, but when I looked at the driver's side it was the same distance but no sound.
I just have recently noticed that it almost sounds like a spring - every time I accelerate somewhat moderate-aggressively it sounds like a spring decompressing in the front pass. side and creaking. Same sound when I brake somewhat rough.
To recap:
- Sounded first like 2 big pieces of metal hitting each other
- Replaced control arm nuts & bults, no change
- Only on Passenger front side, sounds like near the wheel or wheel well
- Moderate-aggressive accel. from stop makes sound like creaking, or spring decompressing
- Moderate-aggressive braking makes sound like creaking, or spring compressing.
Is it possible that the front pass. spring needs to be replaced? Or is it something else?
post Jul 8 2008, 03:16 PM
sounds like it is bottoming out. might be a broken spring.
rbodor
post Jul 10 2008, 08:45 AM
For those in the future that may have this problem:
Front end links. I had loosened them when I was working on the front suspension, and didn't tighten them enough. My advice if you ever work on your front suspension: use a cheater bar to tighten everything.
ON THAT TOPIC, I do need to replace my end links pretty soon. The boot on the joint is starting to look pretty worn. Although there are no real effects yet, I am aware that the OEM end links are weak and a weak link in the chain of this swede brick. So when I do replace (sometime before the end of the year) I will be putting on the IPD stronger endlinks (also supposed to give a little more control over the vehicle)
No New Posts Front Brakes
1 DVPV 33 15th November 2008 - 01:14 PM
No New Posts Front Suspension
Pictures requires
0 Woznaldo 37 9th November 2008 - 02:20 AM
Last post by: Woznaldo
No New Posts Front Bumper ?
Front Bumper ?
0 mlw911 69 4th November 2008 - 08:19 AM
Last post by: mlw911
No New Posts Front Wiper Area Cover
where can I find it?
1 heribertorosas 52 27th October 2008 - 06:14 AM
No New Posts Front Struts
Replacing old ones
6 Volgrrr 222 23rd October 2008 - 02:28 AM
Last post by: Volgrrr
Time is now: 5th December 2008 - 06:58 AM
