> Difference Btw H- Gasket Leak And Exhaust Leak, differences between the two
chef
post Jun 20 2008, 04:58 PM
Drives: 1995 volvo 850
I just wanted to know, because i have some smoke coming out of the engine, not sure if it's from the head gasket or if it's an exhaust manifold leak? it's white in color and usually spills out when the engine is idling and then you give it a quick shot of the throttle....I'm also getting an occasional puff of blue smoke at the exhaust on startup only...i don't have smoke coming out of the dipstick but there is some oil consumption happening....thanks
fabs
p.s the timing has been redone on the car not too long ago...only 176 000 km on the clock...thanks
xpiecemealx
post Jun 21 2008, 09:01 PM
Sounds like you blew the head gasket.
S_E
post Jun 22 2008, 04:30 AM
Out of where in the engine? if it's the dipstick tube it's fairly normal, it's just breathing a bit.
catbed
post Jun 22 2008, 03:23 PM
Drives: 1996 Volvo 850 Manual, 1983 Suzuki GS850GD
yea, sounds like you're leaking coolant.
post Jun 22 2008, 09:02 PM
Assuming you are not leaking anywhere else, and everything is tight, then i think your internals need looking at as well.
BTW, any lights?
chef
post Jun 22 2008, 09:06 PM
hi guys, where there is no smoke coming out of the dipstick....the white smoke looks like it's coming out of the back side of the engine (pass side) between the top of the block and above(or maybe below) the heat shield protector of the manifold...i checked the oil and it feels a little bit gritty and a little sticks?? i'm not loosing any coolant though....can the thermostat not be working properly?
secondly i checked out 2 of the spark plugs (that had been changed not too long ago) and they looked amost brand new not really white (lean) but there is not even a brown tint to them? very odd can it be a blocked fuel filter?
as i mentioned the compression was okay, but i will check again tomorrow. if the compression is high and the piston rings are on the way out, would this have show in the compression test?
is there maybe an additive that can help to remove the sludge in the engine?thanks
ffabs
chef
post Jun 22 2008, 09:10 PM
no no lights are on in the dash.....although, seeing as it's a 95 model is this OBD1 or OBD2? does it have 1 or 2 oxygen sensors (one before and after) the cat? if there would be a problem then it would light up...right?
xpiecemealx
post Jun 22 2008, 09:20 PM
Not a blocked fuel filter. Im stumped but it seems like you have a blown head gasket or valve gasket. Maybe sticking valves....
chef
post Jun 22 2008, 09:24 PM
xpiece..is there an additive i can add to help out the valves,if they are sticking??? i know of a product TKO it's a complete car tune-up additive...valve cleaner, fuel injector cleaner.....i don't have much to loose..right?thanks
xpiecemealx
post Jun 22 2008, 09:29 PM
Maybe one of those oil additives I cant think of the name but its comes in a silver can with a peel back lid at Wal Mart. Or mystery oil. Then I would put in a healthy dose of chevron techron or lucas gas additive it is in a small bottle with a green lid, and see what that does for you. Some swear by slick 50 but I dont like it.
Volgrrr
post Jun 22 2008, 10:53 PM
QUOTE(chef @ Jun 23 2008, 01:06 PM)
ffabs
A product called SEAFOAM seems to get impressive reports. Why don't you have a look through the various Volvo forums to search out and read the relevant threads and user opinions regarding 'Seafoam'.
Most of the ones who have used 'Seafoam' (I guess there are even some on this forum) claim 'Seafoam' has really improved the running of their vehicle - some quite dramatically.
Personally, I have never used 'Seafoam' - simply because it is not sold in Australia.
post Jun 22 2008, 11:23 PM
QUOTE(chef @ Jun 23 2008, 10:06 AM)
If you could ascertain that, it could be a clogged oil line to the turbo, too. On the oil thing, i must ask, are you on schedule for the oil? If you're not losing coolant, then its OK.
A blocked fuel-filter would have caused all the five injectors to experience the same thing. Clogged injectors, however, could do this, though i cant say for sure yet.
I believe so, too.
ffabs
I have used AutoRX on this. No other comments, cos i dont feel much of a difference. However, some people swear by it. I have a friend here who believes in it like 200%!!!
Hehe. Otherwise, Shell has a flushing oil that could be used also for this cause.
chef
post Jun 22 2008, 11:35 PM
AMP...My car is non turbo....
It doesn't look like i'm loosing coolant
I don't know when the fuel filter was last changed...where is it located? where is the fuel injecter fuse located?
thanks again
fabs
xpiecemealx
post Jun 23 2008, 12:50 AM
Fuel filter is under the car. Right under the passenger side rear seat. Do you know what it looks like? If not, its round with a hose going in one side then out the other. Change that annually.
post Jun 23 2008, 05:47 AM
QUOTE(chef @ Jun 23 2008, 12:35 PM)
thanks again
fabs
The fuel filter looks like so. THe one with the black arrow.
The injector fuse is in a black box at the base of the front windshield.
The injector relay is above the radiator, the grey colored relay.
Attached thumbnail(s)
chef
post Jun 24 2008, 04:14 PM
hey guys, i'm thinking that it may be the exhaust manifold as well... right now when i take off, the engine has a bit of a sputtering noise (exhaust sound)...as well i will try to take off the heat shield protector so i can take a look at the manifold and see if it's leaking from there...in terms of the smell, it smells like exhaust with a slight burning rubber smell...any hints? if it is an exhaust leak what symptoms would i get? low torque? spark plug color? lean/rich???thanks
fabs
Engine Coolant Leak
Southerndriver 1,045 12 Today, 10:32 AM
By: mxtaylor49
Ac Leak And Misting
danvan54 16 0 Aug 25 2008, 01:02 PM
By: danvan54
Exhaust Buzz
cheech 34 1 Aug 24 2008, 10:47 PM
By: cheech
Oil Leak
volvo145 67 1 Aug 20 2008, 01:00 PM
By: S60 R
Group Buy For Eurosport Tuning Cat-back Exhaust
Forum : Group Buy
raffneck 31 0 Aug 14 2008, 09:15 AM
By: raffneck
Time is now: 28th August 2008 - 03:35 PM
