> 1994 Volvo 850 - Mass Air Flow Sensor, Symptoms?
stillwelljill
post Jun 15 2008, 06:23 PM
Drives: 1994 Volvo 850
I just had to replace the fuel pump on my '94 850 (non turbo). A few days after replacing the pump, I started having rough engine running when I was starting from a traffic light, stop sign, etc. Sometimes it was rough and sometimes it was perfectly normal running when starting from a stop. Anyway the check engine light was on and when I had it checked out, it read mass air flow sensor. The mechanic cleaned the sensor, cleared the check engine light and the car did a little better for a few days. Yesterday I stopped and turned the engine off to go into a grocery (this was after a really rough start from a stop sign - engine almost died), and now the car will crank, run really roughly for maybe 15-20 seconds and then sputters to a dead stop. Are these symptoms something you would see from the MAF sensor being bad? Wanted to see if anyone else had any experience with the same thing before I spend over two hundred dollars for the MAFS. I have had this 850 for two years and LOVE IT. They are great cars! Thanks for any help.
post Jun 15 2008, 10:48 PM
Try disconnecting the MAF when the engine is running rough. If it really is bad, the engine will run smoother when disconnected. BTW, i reckon you have a lambda light on? Do the code confirm that its still the MAF sensor?
I have yet to change my MAF sensor, as i kept on cleaning and cleaning it, but i have seen a few instances where after a can of contact cleaners, the error still doesnt want to go away. After swapping the MAF with a working one, from another car, it runs OK. In that case, cant help it, dude. Have to change the MAF - the damage is more than just dirty contact points.
Cheers.
stillwelljill
post Jun 16 2008, 12:30 PM
As stated in original post, the mechanic cleared the light after cleaning the mass flow air sensor, and the check engine light has not come back on. All the rough starts from a stopped position and now the engine only running for 20 seconds or so without sputtering to a dead stop are without any light coming on. I will try disconnecting the MAFS and crank and see (if it will run long enough to check) if it is running any smoother without the sensor connected. Thanks for the suggestion.
seanmc87
post Jun 16 2008, 01:10 PM
Drives: 1996 850 T-5
try checking intakes on idle air control valve..
xpiecemealx
post Jun 16 2008, 04:33 PM
Status: ONLINE
What is a lambda light, I dont think my model has it correct me if im wrong but what is it?
rob_russ
post Jun 16 2008, 06:25 PM
Drives: 1995 855 T-5R
had similar problem. car ran so bad had to disconnect sensor, ran better disconnected but stalled everytime i pulled up to junction. paid £150 or $300 for bosch orignal - recomended. if you get any improvement with it disconnected, then replace it.
stillwelljill
post Jun 16 2008, 07:01 PM
Well can't get the car to crank now. It turns over and almost catches but no cigar. Tried disconnecting the sensor and still no crank. It was running great until a few days ago. Not one problem. ??????????????????
When it was running though, there was no check engine light or any light showing (since mechanic cleared the light after cleaning the MAF sensor).
post Jun 16 2008, 07:57 PM
QUOTE(xpiecemealx @ Jun 17 2008, 05:33 AM)
Check Engine Light (CEL)?
Malfunction Indicator Light (MIL)?
Its the same, XPiece.
post Jun 16 2008, 08:41 PM
QUOTE(stillwelljill @ Jun 17 2008, 08:01 AM)
Be careful not to drain your battery out with all the cranking.
Also, look here:-
http://www.volvo-forums.com/t13956-your-en...-wont-start.htm
and/or
http://www.volvo-forums.com/t15505-engine-...t-when-warm.htm
1993 850 Glt Flashing Arrow + Stalling
LVboy1980 397 11 Today, 08:53 PM
By: swedseed850
Volvo V40 Battery
Les-Kirk 736 3 Today, 08:12 PM
By: dougpeng
kleuch48 32 7 Today, 08:02 PM
By: swedseed850
850 Turbo Surging
krdono 40 5 Yesterday, 11:35 PM
By: Volgrrr
Selling My 850 T-5r
littlemommy928 1,650 129 Yesterday, 08:12 PM
Time is now: 29th August 2008 - 09:15 PM
