> Rpm, RPM at 3000 when going 40-50mph
chris93940
post Jun 6 2008, 09:38 AM
Drives: 1993 volvo 940
I have a 1993 940 that has had everything under the sun done. I just had the Crankshaft belt changed and thats when the problem with my RPM started on top of that I had a gas line leak which has been repaired. Can anyone help me by telling me what could be the problem with my car?? Why is it not shifting when at 45mph I'm going at 3000 rpms?
kchinger
post Jun 6 2008, 12:06 PM
Drives: 1993 Volvo 940 Turbo Wagon
Overdrive solenoid most likely. Or the relay for it possibly. Search for overdrive solenoid and you'll find a lot of stuff.
chris93940
post Jun 9 2008, 08:47 AM
Really I was told it was the Regina Rexx system and someone else said it is the shift cable unit.. I have to use the OD button in older for the car to get up to speed and catch up with the RPM.
kchinger
post Jun 9 2008, 12:29 PM
More information would be helpful. What exactly does it do? What do you mean by "using the OD button" to get up to speed? You mean you have to push the OD button in (causing the orange arrow to come on) otherwise it will shift into overdrive too early and bog the engine?
Changing a belt shouldn't affect anything, neither should repairing a gas line leak.
If it's not shifting into OD then it will be running about 2800 rpm in 3rd gear at 45 mph (with your foot on the gas in order to engage the torque converter). This is what it sounds like you're describing.
Just give us more information and we'd be glad to help you.
Kai
chris93940
post Jun 10 2008, 03:53 PM
Ok it just won't catch up with the engine (rpm) when going 20mph its already over 2000 rpm. I was told to use the OD button when I get the car to get up to about 35 than push the button. I have never had a problem with these things before until after I had the craftshaft belt replaced, air fliter, and closed that gas leak the next day after all these things was done the car wouldnt shift up as I picked up speed. The engine goes faster but not the car it self. But after riding for a hr or more it automatically shift in to the correct gears and rides like a dream. But that is after I have been driving for a long period of time.
Paul Gerdes
post Jun 10 2008, 08:58 PM
Drives: 1996 Volvo wagon
Do the easiest thing first change the trans fluid and filter. If its really nasty do it twice. maybe $50. make sure the level is where it should be. Then . . . . ..
kchinger
post Jun 10 2008, 09:45 PM
If the engine is speeding up but the car is not... I'd lean towards transmission slipping. Have you checked your fluid level lately? If it works better after driving for a while it could be because the fluid and transmission have heated up and aren't slipping as badly. Torque converter could possibly be going bad. I'm having trouble relating this problem to either the crankshaft belt, air filter, or gas leak.
If your engine RPM is too high for the speed (which is what it sounds like you're telling me) then pressing the OD button to lock it out of overdrive isn't going to do anything at all. Especially at 20 mph. It won't shift into overdrive until about 45 mph probably, depending upon gas pedal position.
If it isn't shifting up high enough it could be a transmission kickdown adjustment. If it's adjusted wrong it could keep your transmission from up-shifting when it should. It's generally an easy adjustment, but I've never done it on this car.
chris93940
post Jun 11 2008, 09:45 AM
Thats what I was scared of. Transmission slip.. well I put some fluid in yesterday doesnt seem any different but it may not have been enough?? How much longer do you think I have before its gone? I at least need a week. It just started doing this last friday.
chris93940
post Jun 11 2008, 09:48 AM
Also yeah fluid was done about 2 mths ago after I had the trans line replaced and the pan along with some other things.
1998 S70 223k Miles Engine Doesnt Go Over 5000 Rpm
msm15 47 0 Sep 17 2008, 08:32 PM
By: msm15
Rpm For 240 Gl 1989
peacevenus 57 2 Sep 7 2008, 03:06 AM
By: manxman
Engine Rpm
SeaMike 37 1 Aug 24 2008, 03:45 AM
Rattling Noise Around 1.5k~2k Rpm
booyaolian 239 0 Feb 19 2008, 04:09 PM
By: booyaolian
Limited Rpm Power
scvolvo 137 2 Feb 4 2008, 03:08 PM
By: raydar
Time is now: 7th October 2008 - 06:37 PM
