> Front Suspension, heavy vibration
luk726
post Jun 3 2008, 07:41 PM
Drives: Volvo 850 Turbo
my 850 Turbo has a tendency to vibrate heavily when i drive on the freeway.
most noticeable when i hit 60-65 mph.
the vibration seem to be coming from the front passenger tire, but hard to say, since i really just feel it on the accelerator pedal.
do you think a tire balancing would solve it?
i had the front suspension mount replaced last year.
any ideas?
please help.
post Jun 3 2008, 08:45 PM
Have your tires balanced and aligned altogether. The front ones are not properly up, if you can feel the shake on your steering.
blakbyrd
post Jun 4 2008, 01:47 AM
I have a nearly identical problem, except mine hits between 45-55mph. I will mention some more specific symptoms I had and what I have done so far to try to correct my problem, to see if any match what you are experiencing. Lastly I will mention what I have been told is the actual problem with my car (which has not yet been fixed but must be done soon).
Symptoms:
1. Upon reaching 45-55 mph the front end of my car will shake badly, which comes through the steering wheel a fair bit, not to mention the whole car will shake. The shaking always starts right at 45mp and will go away completely past 55 mph. Going uphill during this range makes it worse.
2. While accelerating through this range the shaking is harder and worse while accelerating. The harder I accelerate the harder the shaking is. While in the 45-55mph range, if I let the car coast the shaking goes away. While going down hil it goes away.
Corrections I have tried:
1. I thought my situation was due to balacing and/or alignment. As I was heading on a 500 mile trip to Indiana, I had my wheels rotated and aligned prior to the trip.
The problem remained, but was not quite as bad, however still very noticable.
2. I had then replaced the tires. Upon doing so, I luckly had a great tire guy (friend also), who found that my rims were bent. He fix the rims for me for free, but the problem has still remained as noticable as ever.
3. I even replaced the front brakes and rotors, but I do this anyways when I buy a new car. It made no difference.
Final:
After the above correction, my problem still remains, basically the same as it has been since I have owned the car. I have since been told that the most likely culprit to this is one or poibly 2 bad CV joints on the axleshaft(s). So I am going to replace both front axles soon.
I am pretty certain that my issue is due to the CV joints at this point. Occassionally when I cut the wheel sharply I can hear them pop and crack at times, or while making a 90 degreen turn into a parking lot (or entrance ramp) that is fairly steep or rough, it will make the CV joints pop. It' a pretty noticable sound.
Luckly I only have to drive about 2 miles to work, and I dont go very many places anyways, so I dont have the car up to 45mph all that often, or I stay off the interstateuntil I get this problem fixed. If you happen to have a CV joint problem, this is not something you want to have go out on you while you are driving. I had one go out on my in my pickup once (made worse as I had it lifted with 33 inch tires on it at the time), and you will have basically no control of the vehicle if it goes out, as your front wheels can then point in opposite directions, which is not something you want to have happen while at interstate speeds (it's no fun).
Check your CV boots. They may not always show a problem, but quite often a cracked or busted CV boot will cause the CV joints to prematurely start to fail or go bad.
There are ways to fix a bd CV joint, but in my experience, it has just been easier and more certain the fix is proper to just replace the axle shaft. I dont think this is a cheap fix if you have a mechanic do it (I think the last time I checked each axle shaft was $375 aftermarket, not OEM Volvo, and thats just the Axle, not labor). However, I always replace axle shafts myself (or have done so in the past), so I don;t knowwhat mechanics charge to do this. From past experience, it was not a quick 1-2 hour fix either, and I am expecting on a Volvo that it will be a little more time consuming. Last time I did this on a car, I found that it would have been alot easier just to be able to flip the car over...haha (wish I could have). :)
Just something else to possibly look at.
Boost_Junky
post Jun 4 2008, 09:14 AM
Drives: 1995 850 T5, 1998 V70 NA
Could be many things.
Ball Joint - Control Arm Assembly
Tires out of balance
Rim Bent
CV Joint, although it would ahve to be very bad to casue a vibration
Loose suspenion parts.
Bearing Hub
But mainly this is due to the ball joint. Put your hands at 10 and 2 on the wheel. With the car jacked and front wheels hanging off the ground. Then shake it (make sure you are not under the car). Any movement is a sign of a worn part. If it moves get another person to recreate the movement and you need to look behind the wheel to see where it's giving. Replace that part. When replaced, do it again. "Lather" rince repeat". Vibration will dissapear. Remember certain parts will require realignment.
xpiecemealx
post Jun 14 2008, 05:14 PM
no one mentioned that it could be old bushings mine are squiched to almost nothing left I will get around to it eventually. my same wheel was vibrating I just needed new tires. the new bridgestone potenzas really grip!!!!
post Jun 15 2008, 11:58 PM
:clap:
Suspension To Suspect?
rbodor 16 0 Sep 3 2008, 06:43 PM
By: rbodor
2005 S60 Suspension Rattle
bkfm72 1,085 18 Aug 26 2008, 05:08 PM
2000 S80 Front Clunk, Not Spring Seats/ Struts
cudavid 330 4 Aug 19 2008, 08:55 AM
By: vegasjetskier
Adjusting Front Head Rests
xc90canada 69 0 Aug 9 2008, 10:20 PM
By: xc90canada
Front Suspension Left Side Noise
cdell2333 117 3 Aug 4 2008, 04:16 AM
Time is now: 6th September 2008 - 05:34 PM
