> 240 Ac Compressor Clutch, '91 240 AC Compressor Clutch clicking
PeterFelts
post May 31 2008, 04:42 PM
Drives: 2001 C70 Coupe 2.3L HPT
Please help me figure this one out:
I've got a '91 240 with an AC system that recently stopped working. The first thing that I noticed was that the compressor will click, engage, start spinning and then will disengage itself. This will repeat endlessly but for some reason the compressor will not stay engaged. It will engage for about three seconds, then disengage and continue the cycle.
Any ideas on what I should check? There is one green wire Attached Image coming from the compressor which looks like it goes to the electronic colling fan on the AC radiator. I can't seem to come up with any ideas on testing... I'm thinking that perhaps the electronic cooling fan is not working and the compressor is turning off because it perhaps determines that the AC system shouldn't be running if the cooling fan is not sending a signal? My 240 manual shows that there is a relay involved with the compressor but I can't seem to identify it. I see this part Attached Image but this looks more like a V(+) node than anything else.
Please help me with this one...
PeterFelts
post May 31 2008, 05:23 PM
Now I'm thinking that either this relay or the pressure sensor is malfunctioning. The reason for this is that I believe that I traced the green wire mentioned earlier to a pressure sensor, which would agree with this diagram Attached Image. Perhaps this pressure sensor is sending the wrong signal to the compressor, resulting in the compressor shutting off. Either that or the relay (which I still haven't located on this car) is malfunctioning (Item K).
Can anyone tell me where this relay is?
post May 31 2008, 06:26 PM
Drives: 1988 240 GL
sounds like low gas pressure to me-bridge out the switch on the top of the drier on the right hand side of the radiator with some thick wire strap, and see if that stops it cycling. do NOT prolong this test, as a low gas compressor is damagable by continuous running-hence the switch. The aircon relay is in behind the central dash, near the thermostat. expect gas conversion to R134A, regardless. R12 is illegal/difficult to obtain.
1987 240 Emissions
gwiz 174 21 Yesterday, 07:16 AM
By: manxman
1993 240 Wagon - Wipers Only Work On High
Lyle_s 266 10 Aug 27 2008, 10:58 AM
By: Lyle_s
93 240 Intermittent Crank Problem
mxwlhaus 39 1 Aug 23 2008, 03:53 AM
By: manxman
850 T5 Ac Compressor- How Tricky?
VAVolvoDriver 37 2 Aug 21 2008, 06:03 AM
240 Wagon Antenna Replacement
Teenonator 419 9 Aug 20 2008, 01:27 AM
By: Teenonator
Time is now: 29th August 2008 - 09:45 PM
