> 90' 760 Turbo Ignition Horror, intermitent ignition cut off
abby41702
post Apr 2 2005, 02:46 PM
Drives: 1990 760 turbo wagon
:haha: :angry: heres the deal , i have a 1990 760 turbo wagon with a b230f motor and a jetronic system . when the car runs it runs great, but no matter what speed you are driving it will cut off and not come back on until the car was stopped put in park and restarted in the park posistion, now it starts sometimes but mainly not. can anyone help, ive checked all the fuses, all ok, when key is in the on posistion there is no power at the coil?
post Apr 2 2005, 10:21 PM
There is 2 things to check.1 check the engine speed sensor it is located on the back of the engine where the engine and trans meet.There is a sensor that mounts at the top of the trans.If the outside sheilding is cracked or missing at all replace the sensor.Also check the power stage mounted on the inside of the left side front fender in the engine compartment.It is a sensor mounted on an aluminum plate.
They will both cause the complaint you have.If the speed sensor is good when the car stalls you can try tapping on the power stage and see if it starts.
abram
post Apr 4 2005, 10:40 PM
Drives: 760 GLE
I had identical problem as you experiencing.
My 88 760 GLE would stall any time (There was no constant time frame) It could happen when I stopped in front of the traffic light waiting; Or it happened even when I was driving high speed, restarting was no problem but only troublesome.
My problem solved when I went to the junk yard & found a replacement Ignition Control unit $10 & changed it.(New one cost $80)
That unit located under the air filter holder, you'll remove the air filter box completely and it will expose the Ignition Control unit mounted on the left front wheel cover by 2 screws, with a set of wire pluged into it.
I would say there is 99.5% possibly will solve your ploblem.
Good luck! :)
Turbo
mardidista 69 1 Sep 5 2008, 10:19 AM
By: nicolaselias
jfman 56 1 Sep 4 2008, 09:34 AM
By: sean_cummings
ndan85 46 1 Sep 2 2008, 11:46 PM
By: S60NV
Low To High Pressure Turbo?
Forum : Performance
hastings 194 8 Aug 30 2008, 09:50 AM
By: volvo spec
440 2.0 Turbo Conversion/hybrid
Woznaldo 115 4 Aug 29 2008, 11:50 PM
By: Woznaldo
Time is now: 7th September 2008 - 11:23 PM
