> Help My Spedo Just Went Poof
wwdragon
post May 27 2008, 04:59 PM
Drives: 1989 Volvo 740 GL, 1991 Chevy Lumina APV
Hi all
Wee bit of help please. Just now my spedo went poof, it didn't just die though. At first it would show correct speed until I hit a bump then it would drop and come back up to normal.
Then it showed 0 speed unless I hit a bump in which case it would show correct speed for a second and drop back to 0.
Now it's not doing anything at all and the odometer isn't working either.
Help? Where to look first? Can it be a loose fuse? (doubt that) please if any of you can help, the car is a 89 740GL Sedan non turbo and I would like to see if I can fix it myself before bringing it into the garage :)
Thanks in advance.
wwdragon
post May 27 2008, 05:22 PM
Drives: 1968 SS clone Camaro,1963 pan/shovel chopper, 1949 Panhead bobber, 1967 Triumph Bonneville, 1967 Honda 175, 1999 Suzuki Hayabusa, 1996 Impala SS big-block, 2004 Mercedes E500 (the mrs.), 1934 Dodge,
sounds like it might be the little gear inside. try fcpgroton.com for the parts. a little pain in the butt to get out, but easy as hell.
wwdragon
post May 28 2008, 06:47 AM
QUOTE(wwdragon @ May 27 2008, 05:59 PM)
Hi all
Thanks in advance.
wwdragon
[right][snapback]81481[/snapback][/right]
Thank you small question, just what part am I looking for? I have been going thru the site but can't seem to find it. Then again I don't know what the part is called either :)
edit: I found a speedo Transmitter is that what I am looking for? If so I can only see a model for the 1988 model of the 740. Would that work anyway assuming this is the part I need.
Thanks again
wwdragon
finntexan
post May 29 2008, 11:45 PM
Drives: 1991 Volvo 740 2.3l Sedan
I think the gear affects the odometer only, speedo is usually electronic.
Could be a broken component in speedo/odometer unit, or a loose (ground)connection.
Easiest fix is to get the whole instrument cluster from Ebay, they sell for around $50 there.
wwdragon
post May 31 2008, 12:14 PM
QUOTE(finntexan @ May 30 2008, 12:45 AM)
[right][snapback]81763[/snapback][/right]
Well I fixed it :beer: I poked my nose under the car and didn't see anything loose, then again I really didn't know what I was looking for to begin with heheh.
So I popped out the cluster and again nothing was loose, now mind you all I know about cars is change the oil, put gas in, turn the key and it goes vroom vroom when I hit the gas. :)
Anyway I see the wire that goes to the Speedo and tug on it, all tight, pulled it out, put it back, tightened everything back there for good measure, put it all back and somehow it's working again :)
So a hearty thank you to everyone and to the poster above me as from the way it died I knew it had to be a loose something somewhere.
Beers for everyone!
wwdragon
post Jun 1 2008, 12:45 PM
Update
It's not working again, I did the same thing as yesterday and poked and prodded in the back of the cluster but nothing, it also died the same way as it did the first time.
I know it's a loose something but for the life of me now I a stumped.
I will be looking into a new cluster from Ebay however I would love to fix this myself :)
wwdragon
wwdragon
post Jun 5 2008, 04:58 PM
WooHoo 100% fixed!
I got a friend to bring over those ramps an put the back tires on it. Now that I had a better point of view I looked to where you guys said the sender unit would be on the rear axle.
Sure enough I found it and I found a cut wire. Spliced in some new wire on both wires for good measure fired up and car and everything works like a charm.
Again a huge thank you to all of you in this form, you just saved me a bunch of money as one place I called said a 4 hour min charge for electric problems.
Thanks again.
wwdragon
Barry
No New Posts My 854 Pcv Job
9 70 140 39 Today, 04:45 AM
No New Posts Topic has attachmentsMy 1999 S80 T6 In Winter.
My S80 T6 after good wash and Turtle Ice Wax.
3 yuri_yermilov 39 31st December 2008 - 06:11 PM
Last post by: yuri_yermilov
No new Topic has attachmentsHelp Help Help T5r
Umm - Bad head?????
29 littlemommy928 165 31st December 2008 - 01:07 AM
No new Topic has attachmentsMy Engine Has Started Ticking Like A Bomb!
67 suitslayer 671 30th December 2008 - 11:38 PM
3 Ryan921 66 30th December 2008 - 11:26 PM
Time is now: 9th January 2009 - 09:25 AM
