> V70 1998 2.5 Lpt, Cabin Air Filter
P3DRO
post May 27 2008, 02:23 PM
Drives: 1998 volvo v70
:00000732:
Hello all
CABIN AIRFILTER ? ......
I have seen a post somewhere here in relation to the Cabin Filter but there were No Replys .............................
(1) Where is this Filter located ?
(2) How do you change it ?
There is an odour as you turn On the heating but then goes away or maybe my nose gets used to it :lol:
Your input would be greatly appreaciated i have posted a few posts here before but so far im still waitng for an answer on them YET :grin: #
Kind Regards ........ :liebe011:
post May 27 2008, 03:22 PM
Status: ONLINE
it's either under your dash, passenger side, or check under the hood, back by the windshield, you'll have to lift up the black panel where your wipers are, there should be a couple of clips there. the filter is a pull off and lay on type of filter. good luck.
P3DRO
post May 27 2008, 03:43 PM
:liebe011:
I will have a go at it ......Will post feedback
Cheers
P3DRO
post Jun 17 2008, 03:26 PM
:liebe011: for the info
In UK the Pollen filter/Cabin filter is under the hood by the passenger side just below the wiper blades remove the plastic and you wont miss it :beer:
paullus
post Jun 26 2008, 10:41 AM
Drives: 1998 S70 LPT with RICA 235bhp remap.
Hi
I've just fitted a new filter. However in the UK some 2.5LPT models weren't fitted with a cabin filter. I don't know if this applies in the States I had to get the filter housing off a V70 in order to be able to fit a filter. This is very easy to do however. The filter housing is located beneath the plastic cover which lies between the base of the windscreen and the rear engine bay bonnet seal. To make the job easy you need to remove the windscreen wiper arms. Then undo the torx screws holding the plastic cover in place. Carefully pull the cover forward to release it from the trim at the base of the windscreen and lift it clear. Removing the filter is a piece of cake and the replacement just clips in.
Regarding the odour. It could be a dirty filter. However the most likely cause is bacteria in the system which accumulates over time and apart from smells can cause eye, throat and chest infections. This can be cured simply by using an aircon conditioner. These are available from spares shops. I used one made by Comma. You set the aircon on max cool with the fan on full and the recirculation function on. You place the aerosol in the rear footwell with the front seat pushed right forward, set it off and shut the door. The can sprays for about ten minutes and the vapour is sucked through the system killing the bacteria and deodorising the system.
Hope this helps.
Regards.
Bad Am Radio Reception - 2000 V70
sagreer70 30 2 Aug 26 2008, 02:15 PM
By: sagreer70
V70 T5 Coolant Amount
peppyshome 31 1 Aug 24 2008, 11:32 AM
By: Tech
1998 V70 Multiple Misfire
taskafa 110 2 Aug 24 2008, 11:30 AM
By: Tech
2002 V70 Fuel Door Problem
rimfman 7,629 21 Aug 23 2008, 09:38 AM
By: jrevkin
Totally Locked Out Of V70 1999
hallinguk 103 1 Aug 20 2008, 11:39 AM
By: striderwilson
Time is now: 29th August 2008 - 09:28 PM
