> Volvo 440 Glt 2.0, Help Me Pleeaaassssee!!!!!!!!!
jonvolvo440/2.0
post May 27 2008, 12:23 PM
Drives: m reg 440 2.0
Can anyone Help me please!!!!
The problems i am experiencing are as follows:-
Car starts fine,But isn't too happy idling,sounds as if it's missing in lower revs it'll run as long as you want but either way isn't happy idling if I turn it off and try and start it again it'll turn over but won't start When doing this (refusing to start) I get pops from the exhaust and a strong smell of petrol from the exhaust.
If i then leave it for a couple of days, (yeah days!!) It'll fire and run first turn of the key but with the same symptoms as above.
This all came about after it ran out of fuel on my drive it was running great before that,I've so far replaced the battery cos the old one was goosed although i did let some **** so called mechanic have a look and came home from work one afternoon to find he had connected the batery charger directly to the battery without disconnecting the battery from the car, Could this have damaged anything????.
The Car is an M reg Volvo 440 Glt 2ltr with multipoint injection
Any help would be grealy appreciated, I don't want to have to scrap it!!!
cheers
A Sad Volvo Fan.
billy.mc
post May 29 2008, 03:22 AM
Drives: 1994 440 si called MAX - standard as a second vechicle, main car VX Frontera 2.3TD '92, called Big Monster - Custom dials, snorkle, limo blacked, lift & snorkle in progress, roof top photography platform in progress, heavy AT's all round.
hey sounds like your may have the same probs as mine, as mine was having trouble idling & running she was pulling/jerking! sadly i aint had no reply's back but if you keep an eye on mine as well some one may have a solution, just a thought have you checked / changed the fuel filter?
Foto
post May 29 2008, 09:03 AM
Drives: 460 turbo, 440 turbo
hey guys, i went to a mechanic and he said that my Luftmassmeter (air flow) has gone. i will try one from other car, and i will post my results :D
billy.mc
post May 29 2008, 10:49 AM
cheers bud look forward to the results :)
jonvolvo440/2.0
post May 29 2008, 12:24 PM
:liebe011: Haven't checked filters yet they were aparently new when i bought the car about 1 yr ago.
I've just got hold of the diagnostic codes so thats a possible try, I've also managed to get a copy of VADIS so hopefully that'll help.
I'll keep you guys posted an hopefully between us we can save thecars from the crusher.......
grendel1960
post May 29 2008, 01:06 PM
If its the air mass meter (thats the thing up on the shelf jus in front of the windscreen, then check the vacuum hose, mine got blocked at the restrictor (injector end) and caused all sorts of problems, worth a look anyway, so the unit may not be faulty in itself, I went through 3 different units before I found this.
Grendel
jonvolvo440/2.0
post May 29 2008, 02:50 PM
:liebe011: Cheers GRENDEL wil give it a try mate
Would that be a small black box with a hose that comes out through the bulkhead then goes onto rigid pipe which then goes to the left hand side of the manifold (looking from the front)??? just that when i got the car this hose kept popping off which caused the car to run rough so i tie wrapped it back inside the ropey bit which comes from the manifold.
Went out earlier checked diagnostics came back 1-1-1 though the car started first turn this time it ran better than normal, so i turned it off and started it again it started first time (BIG SURPRISE). Got Cocky after letting it run for a bit turned it off again and guess what happened..... yep won't start , Back firing through exhaust but not running.
Still I Aint going to give up on it it's too good a car to strip/scrap.
grendel1960
post May 30 2008, 01:14 PM
thats the part, if thats disconnected the car thinks its running under ground level as it doesnt get any vacuum, and adjusts timing and fuel to suit. if its blocked its a similar case, if the pipe is loose it might be leaking vacuum and not operating correctly, I replaced mine with one from a breakers, and made a point of getting a new pipe too, it was the pipe that eventually cured it, I found the old one was blocked.
Grendel
No New Posts 2001 Xc V70 Seems To Grab Or Slip..
1 sharpeirescue 9 Yesterday, 04:14 PM
No New Posts Volvo Coolant
where to buy
1 volvolover 243 Yesterday, 01:47 AM
No New Posts 2005 Xc90 T6
To purchase or not?
7 alikat 585 18th November 2008 - 03:26 PM
Last post by: alikat
volvo s 40 emission class
0 krlegorky 4 18th November 2008 - 12:17 PM
Last post by: krlegorky
No New Posts 2001 S80 2.9 Needing O2 Sensors, Mass Airflow, Timing Chain, Spark Plugs, And More!
Holy jeepers, 4000 bucks
1 kabifff 19 17th November 2008 - 08:29 PM
Last post by: jlewisinsyr
Time is now: 20th November 2008 - 03:17 PM
