> Timeing Belt Crank Pulley Bolt Tip
Weezy
post May 26 2008, 01:51 PM
Drives: 1997 940
I got this tip for removing the crank pulley bolt without resorting to special tools from another site,its really ingenious and simple.........................
1 - Pull plugs and rotate crank to #1 0° TDC Compression
2 - Verify #1 and #2 valves closed - look thru oil fill hole, #1 cam pointed slightly up and inboard, #2 pointed horizontally outboard.
3 - Rotate crank about 90° past TDC.
4 - Stuff about 3 feet of clothesline into # 1 plug hole, leaving 6" outside (feeding the rope in thru a short length of heater hose makes the job even quicker).
5 - Rotate the crank backwards until the packed rope stops further rotation.
6 - Use socket, breaker bar, and pipe extension to loosen pulley bolt.
7 - Tighten bolt the same way, but start with crank about 90° before #1 TDC Comp.
8 - When tight to spec, back the crank up a little and remove clothesline.
post May 29 2008, 03:30 PM
Status: Online
nice one, weezy.
No New Posts Crankshaft Pos Sensor Fault P0336
1996 / 850Turbo
5 Alextoo 150 17th October 2008 - 06:12 PM
Last post by: swedseed850
No New Posts Crank, Crank, Crank, Buzzzzzzzzzzz
Starter Dead?
4 sargesvs 97 27th September 2008 - 05:58 PM
Last post by: sargesvs
No New Posts Belt Woes
There's a trick to this I need to know w
4 Tinkerbell 109 21st September 2008 - 06:05 PM
Last post by: manxman
No New Posts Bolt Pattern For 1990 240 Dl
3 asmarshall88 171 11th September 2008 - 08:53 PM
No New Posts Bolt Pattern?
6 xpiecemealx 264 11th August 2008 - 10:40 PM
Time is now: 20th November 2008 - 04:08 PM
