> Cold Start Idle
scorpioaddict
post May 25 2008, 08:39 PM
Drives: Merkur Scorpio
I've got an 87 244 that shakes bad at cold start idle for up to a minute, then it clears. I found the temp sensor wire was disconnected, put it back on, and it seems to shake less now (less vibration and less time). I'm wondering if that's the computer trying to compensate and if I can reset it by disconnecting the battery.
The car's had a ton of work around the fuel system, including a new idle air valve. The repair shop claims they can't fix the idle because the car needs a new wiring harness. The wires look okay, though a couple of plastic terminal covers have disintegrated. And it runs perfectly once past cold idle.
post May 26 2008, 02:02 AM
Drives: 1988 240 GL
disconnect == reset! give it abt 5-10min to be sure. if temp >0deg C then anti knock sensor not operating, due to normal cold motor noise level-so timing can get too advanced when motor very cold. - suggest you check the mircoswitch on the throttle butterfly for good electrical operation and adjustment-it MAY provide a counter to the overadvancing for idle - but I don't know it will. BTW a little patience and skill and you can replace the wiring DIY. It's not a difficult job, though it takes a little time. or u can buy one as a harness part, and fit it yourself, again, not difficult. see ebay for quite a few bits, and use the web search engines for other info/parts/suppliers.
scorpioaddict
post May 26 2008, 03:37 AM
Thanks! If the reset solves the idle, I'm gonna let 'er eat the way she is. I've already spent three full days on other wiring.:wacko:
Next up, new a/c clutch, then home to her momma.
post May 26 2008, 09:44 AM
Drives: 1988 240 GL
make sure any vacuum line to the ignition module is not leaking. will cause some serious problems if you haven't got enough advance, and the leak can compromise the idle mixture.
scorpioaddict
post May 27 2008, 03:04 AM
The shaking has subsided considerably on cold start (60º F). It still has a few seconds of rough-running, but overall it's close to right. Computer doesn't want to give it up :)
Black Smoke, Rough Idle On '99 S70
garlinto 31 2 Yesterday, 02:15 PM
By: garlinto
Immobilizer - Start Inhibitor 02 Awd S60
redheath 1,227 12 Sep 4 2008, 10:33 PM
By: milo123
Car Doesn't Start
itwasntme 111 3 Sep 4 2008, 08:25 AM
By: dt19249
1999 S80 T6 Idle Problems Again
draco 49 3 Aug 31 2008, 07:20 PM
By: draco
Volvo 850 Dying After Idle
youngvolvoowner 37 3 Aug 31 2008, 01:38 PM
By: youngvolvoowner
Time is now: 6th September 2008 - 12:17 AM
