> Who In The World Invented The Washer Pump On 850?!, I have a problem
barrythedude
post May 10 2008, 09:21 PM
Drives: 1993 850 glt
I cannot get it to spray, the motor runs but isny putting anything out. I have traced all the lines back to the pump. Is there no hose in the bottom of the motor to go into the washer? My service manual has none, but I sure think it should! There are also two hoses that I think lead to the headlights that are unhooked, probably got as frustrated as I did. Any advice is appreciated thanx!
post May 10 2008, 10:32 PM
try a pin and insert it into the holes to clean out any crud that might accumulate there. also, unplug the hose from the nozzle and see if there is fluid shooting out, then you know that something is in the nozzle. if nothing comes out and the pump works, it's the hose.
barrythedude
post May 10 2008, 11:24 PM
Thanx for the reply! I have no hose on the bottom connector, should there be one?
Volgrrr
post May 10 2008, 11:25 PM
QUOTE(TheGreekMason @ May 11 2008, 02:32 PM)
I think TheGreekMason's suggestion is the logical thing to do.
However, if doing this doesn't solve your problem then you will have start your investigation right back at the the washer pump motor(s) and work your way forward along the various pieces of tubing until you find where the blockage is.
There is also a little one-way valve in the washer system which can freeze and prevent the washer fluid from getting to where it should.
I have also known the little cogs in the pump to jam up with accumulated gunk. If this is the problem you will have to clean out every last skerrick of gunk as these cogs mesh with a very fine tolerance and therefore jam easily.
Good luck!
barrythedude
post May 11 2008, 07:45 AM
My guide with pics illustrates the pump coming out (I can do this) but the pic shows the bottom spigot not having a hose on it (The one going straight down into the jug) Sure appears to me like there should be one, can anyone confirm? Great site :57:
barrythedude
post May 11 2008, 07:55 PM
Does anyone have a Tridon part number for a replacement>? I put in in water and gave 12 volts, it made noise, but didnt pump at all, methinks seized.
post May 11 2008, 07:57 PM
the washer pump?
barrythedude
post May 11 2008, 08:06 PM
yes sir!
post May 11 2008, 08:09 PM
dude, try fcpgroton.com cheapest place for parts.
Volgrrr
post May 12 2008, 01:00 AM
QUOTE(barrythedude @ May 12 2008, 11:55 AM)
Yeah - that's the motor trying to turn the seized-up pump cogs that I referred too in my last post. Drop the bottom of the pump off and have a geek at it. However, if you have stacks of money, then don't worry about it - just throw it away and buy a new one.
barrythedude
post May 12 2008, 07:33 AM
To drop the bottom off, do I pry on those two white clips? It seems to be molded as one unit - I guess because it has been together so long. Thanx for a reply, and thanx for all the help!
barrythedude
post May 16 2008, 08:49 PM
Hey all, can I add an aftermarket pump? Do I just place it inline and use the old pump to seal at the reservoir? thanx for any input!
barrythedude
post Jun 1 2008, 04:11 PM
Wow, had a pile of wires and hoses to disconnect to undo the headlight wiper/washer combo. A little grinding, sanding and bending and I got an aftermarket one to slide in and works like a charm. Not really well designed in my HO, and I have the cuts on my large hands to prove it :) beer time :beer:
850 Turbo Stalls When Hot Outside
optimus234 52 7 Today, 10:21 AM
By: xpiecemealx
'94 850 Turbo With Some Serious Issues
KDK241 14 1 Today, 02:32 AM
By: blakbyrd
Selling My 850 T-5r
littlemommy928 299 37 Yesterday, 05:54 PM
By: Tech
1995 850 Glt Engine Swap
reitterer211 12 0 Jul 2 2008, 05:57 PM
By: reitterer211
1993 850 Glt Sedan Eng & Tran Swap Out
sixblade 114 11 Jul 2 2008, 05:23 PM
By: sixblade
Time is now: 4th July 2008 - 10:45 AM
