> High Mileage 940 With A Few Problems
Primergy
post Apr 28 2008, 10:08 AM
Drives: 940, 740
Hi, we recently bought a 940 with almost 270.000miles
The car came from a well situated home and has extensive service records.
However I think the alternator just died.
Please help me determine this and tell me if a few other quirks and problems might be related to that.
The car was driving fine when we bought it.
Over time it developed an idling problem.
The car would sometimes have a hard start, idle fine when cold.
Once the engine is warm the engine starts to idle rough and shakes the whole car!
Especially at the next stop light after a few hwy miles. Sometimes the engine would die, hesitates for 2-3seconds when
you accelerate, then spins up and drives fine.
A local mechanic (specialized on Volvo) wanted to replace all EGR parts (vacuum leaks?!).
We did not decide to do that but instead drove it to a relative who is also a mechanic (non-Volvo).
He had problems getting the idle under control, succeeded but did not find any vacuum leaks!
On the way home all lights in the dashboards came on (dimmed, you could for example pull the e-brake and the according light would come up all the way).
after another 40miles the car died twice on the highway.
Trying to start the car you could hear a "click" from the engine compartment, that was it.
(My wife was driving the car, I was in another vehicle behind her).
Suspected that the alternator died. But why so sudden like that?!
All alternator related problems I had before were slow, bad starts, empty batteries etc.
We towed the Volvo home the rest of the distance and at home it would start again,
this time it had a bad start and the starter barely managed to get it running.
Here are my questions:
Any ideas about that Idle problem we had and might turn up again?
Any other clues what could be bad, affected besides the alternator?
It is a good Denso alternator, would it be possible / wise to just change coals and voltage regulator?
We would like to push the Volvo over the 300.000mile mark and it is a daily beater, we rely on it - what affordable alt. exchange / repair would you propose.
Everything from 20$ for a used one at "Pull A Part" to 400$ for a new Denso seems possible.
About me: I am not a mechanic, my car repair experience is limited, however I am willing to learn.
I moved from Germany to the US a few months ago and did not really have need and money for my own car in Germany - given the public transportation system in bigger cities.
post Apr 28 2008, 10:48 AM
seeing as the alternator is a decent make - denso as you say. I see no reason why the coils would die, if it smells all burnt out then it is obvious, but if not it is probably just the voltage regulator,w hich you should be able to pick one up reasonably cheap compamred to a new alternator.
All sorts of problems can be caused by a die-ing alternator, mostly from what you have described as the engine running will draw current from the battery all the time, a lot more than people think!
The clicking under the bonnet will be the starting mechanism. this will be a few relays which will switch power to the fuel pumps and the starter motor. If there isnt enough juice left in the battery, you will hear the click but no cranking will happen.
Get the car running, probably by jump starting it and leave it connected and get a multimeter on the battery terminals ... when running at idle it should be at about 13.8v, 2 or 3k rpm no more than 14.2ish.
If its less then the battery will be drained beyond saving, if more then your battery will probably be melting ...
Primergy
post Apr 28 2008, 12:07 PM
Drives: 940, 740
Thanks for the info!
The battery is still fine. For now I hooked it up to a neighbours charger.
*charger and jumping cable have been added to my shopping list
I only find V-regulators for Bosch alternators.
If the Nippon Denso alternators have a different regulator I need help finding some.
:rolleyes:
post Apr 28 2008, 01:08 PM
ok. Start to check vacuum lines, get your mechanic friend to help you with this, there are a few, check for any pipes that look fatigued etc.. and replace them if they are split.
chris945
post May 16 2008, 11:18 AM
Drives: 1992 Volvo 945, 2002 Honda CRV, Porsche Boxster S
Hi
On a car with this mileage I would:
1. Replace the alternator brushes - they're cheap, easy to fit and they wear out giving the symptoms of alternator failure.
2. Get the injectors cleaned professionally - injector cleaner is a waste of time on a car this old (I know, I've got one too!). This helps the driveability no end.
3. Clean the throttle body with injector cleaner (NOT CARB cleaner). This will sort out the idle problem almost certainly.
My 940 has done 250,000 miles and runs beautifully now after just doing point 2 and 3.
Probably worth changing the oxygen sensor too.
Hope this helps
Chris
What Mileage Do You Get?
rosso75 366 42 Yesterday, 09:09 PM
1995 940 Radio
E$$volvo940 82 3 Jul 3 2008, 09:41 AM
By: E$$volvo940
V50/v70's Reasonable Mileage Limit
Forum : Volvo V50 Forum
bzzi 26 0 Jul 2 2008, 06:00 PM
By: bzzi
Will V70 Wheels Fit On 940
adburt 19 0 Jul 2 2008, 02:43 PM
By: adburt
Engine Problems
Bizze 17 0 Jul 2 2008, 05:59 AM
By: Bizze
Time is now: 5th July 2008 - 06:54 PM
