> 92 940 Turbo Engine Noise, noise goes on and off
wabbacha
post Apr 22 2008, 09:08 PM
Drives: 940 turbo
my 92 940 has a strange noise thats goes on and off, it sounds like its in the engine, but it goes on with a click sound and imediatly turns off the same way, some times its a minute sometimes its near 5 minutes.
its a squeling noise near or around the timing belt/ front of motor, i checked the timing belt for the fun of it, but i realize it does it when something turns on intermitidly its not my a/c, p/s water pump or alt, i removed all belts it aint my timing for i had the cover removed.
it realing seems as if a soleniod or switch is engaging and it starts to make the noise, sounds like a high pitched rubbing noise, like when an air pump goes bad, but not sure if mine even has an air pump and if so not your typical engine driven pump.
any help would be greatly appreciated.
post Apr 23 2008, 02:07 AM
what do you mean by air pump?....
the only thing i could think of that would make a switching noise and squeal would be your alternator. On the back of the alternator there is a small black bosch device called a voltage regulator, this regulates the voltage to a constant 14v maximum regarding the rpm of the engine.
sometimes this can break down and stop working but i wouldnt have thought it would make the squealing noise.
when this squealing noise occurs does the car drop a few rpm's say on idle at 900 would it drop to like 750? noticeably straining?
also can you detect which side of the engine this noise is coming from, eg turbo side or inlet side... front of engine/rear of engine.
a little bell has just gone off in my head now, arent the oil pumps on these motors electrical?
wabbacha
post Apr 23 2008, 05:02 PM
Drives: 940 turbo
well the alt belt was off and the noise persited...
but now you got me thinking about the oil pump, the noise sounds internal, as for were i'd say front/ front left.
there is no rpm drop, the car runs normal...
i like bells and whistles going off, but i dont like pistons and rods going off.
i'll check the oil pump next.
post Apr 24 2008, 03:22 AM
front, front left ... of the engine as you look at it. That would most likely be the water pump.
this has now sprung into my mind that could be possible. it would still work even with duff bearings, but would make hell of a noise. the way to test it would be (with engien off) take off the belt and see if you could turn it by hand.
This should be quite easy and free moving ... if it isnt then it is most likely the bearings have gone and are heating up.
Also i think if you have a fan on your motor (not electric) it could also be the fluid clutch on it. as these eventually wear out. The rotation of the engine spins the clutch around heating up the oil inside it and when the oil inside heats up it becomes thicker thus dragging the other side with it ... kind of like an automatic gearbox for an easier comparison...
try these.
wabbacha
post May 6 2008, 05:37 PM
Drives: 940 turbo
oy veh! its the dang timing belt tensoner!
i must ov over looked it, i started the car when the cover was off and the motor was cold and it didnt move, than as it began to warm up it slowly started to move, than stop than move, than stop and so on.....
looks like its gettin a new belt and pully!
its ok cuz i got 140k+ miles on her and the belt has signs of craking, i was gonna change it anyway...
thanks for the help tho :liebe011:
:amen:
woot woot
post May 10 2008, 06:05 AM
no problem, would have said that after the water pump anyway. give us a update on how it goes and if it solves it :)
wabbacha
post Jun 23 2008, 01:43 PM
Drives: 940 turbo
well new t-belt, tensioner pully, water pump, all new hoses, seals, and head gasket including full tune-up (plugs, volvo wires and volvo cap, baster coil and fuel filter) had the head surfaced + pressure tested.
since i bought the car used roughly a few months ago with 138K on it i figured i'd go the whole nine yards and replace and fix the whole thing, the next thing to do is the oil pump and complete brakes. after that my car will be like new.
did all the work myself so i saved a bundle on it.
and all becuase of that dreaded pulley noise.
:liebe011: for the help mate.
T4 Engine Problem
nickfev 52 2 Yesterday, 03:46 PM
By: bushytale
850 Turbo Overheating After Restart
meangreenmachine 42 8 Oct 8 2008, 09:46 PM
mike_281 61 5 Oct 8 2008, 07:20 AM
By: IceBrick
Fastest Engine For 240
duffy 108 6 Oct 8 2008, 04:12 AM
By: Volgrrr
S40 Engine
resevil 87 2 Oct 8 2008, 02:19 AM
By: S40guy
Time is now: 10th October 2008 - 02:23 PM
