> P0422 - Check Engine Light, Main Catalyst Efficiency Below Threshold
scookstlmo
post Mar 26 2008, 01:36 PM
Drives: 2000 S70 GLT, 2000 S70 SE
I've got a 2000 S70 Volvo GLT (turbo) with a CEL OBD II code of P0422 which I reported to the dealer last June (07) while the vehicle was under the 8 yr/80K emissions warranty. The dealership said that this code was caused by a bad brake booster (vacuum leak) although I indicated that there were no noises or problems braking. I insisted they investigate the catalytic converter but they refused. Now, 9 months later, I am experiencing the same issue - P0422 code and the dealership is now indicating that it's a bad catalytic converter. I insisted that this should be addressed under the federal emissions warranty but the dealership is refusing because the vehicle is 'technically out of warranty by 4 months (but still under 80K).
1) was I sold a bill of goods with the brake booster?
2) shouldn't Volvo cover the catalytic converter since it was originally reported while vehicle was under warranty but the dealership muffed correcting it?
3) two weeks ago the CEL came on with this code and I reset it. It came on two weeks later after 400 miles. That's when I took it into the dealership this past Friday.
4) dealership last Friday just reset the CEL and told me to drive as-is
Doesn't this sound irresponsible and just totally wrong? CEL has been off now again for over 150 miles since the dealership reset it.
Anybody have any suggestions? The car has always ran fine and if it weren't for the CEL, you wouldn't know there was a problem. I have reported this to Volvo Customer Care but am interested in hearing about similar experiences or catalytic converter issues. Thanks in advance.
raydar
post Mar 31 2008, 02:04 PM
Drives: 2007 s80 d5
I would be suprised if your cat is at fault if the car still has the original volvo one fitted, has the garage tested the emissions of the car to see how the cat is performing! If the emissions are ok it may be a rear 02 sensor causing the problem.
scookstlmo
post Mar 31 2008, 02:19 PM
unfortunately no, this dealership is rather suspect and I do not have any trust or confidence in its ability to correctly diagnose the problem. BTW, the CEL came back on Friday evening and I have an independent/reputable Volvo repair facility looking at it tomorrow.
I've referred the matter to Volvo Customer Care(less), but so far have not been provided with an acceptable remedy to this issue. I am rapidly losing my confidence in Volvo due to this and previous problems that I've had with this vehicle after the extended warranty expired, e.g. new master cylinder, new brake booster, and now a catalytic converter (which should have been replaced last year under the fed emissions warranty). Has anyone else had these problems on a S70 with less than 79K miles?
With respect to the rear oxygen sensor, I understand that they should only be replaced if they fail, but the front sensor should be replaced every 100K for efficient and trouble free operation.
This vehicle passed emissions testing in January of this year for tag renewal.
raydar
post Apr 1 2008, 12:55 PM
Drives: 2007 s80 d5
i would not change a o2 sensor unless it fails, yes it will not operate as efficiently as it gets older but if passing emissions then why fix whats not broken.
The rear o2 sensor does not effect your emissions its purpose is to check the operation of the front o2 sensor (yes I know one sensor to check another) and also to check the operation of the catalyst. It is the rear o2 sensor that decides if the engine management should log a catalyst fault, so if the rear o2 sensor is reading wrong it can tell you that a perfectly good catalyst is faulty when its not.
MechChick
post Jul 11 2008, 08:26 AM
Drives: GMC C3
I'm a mechanic working on & off on my boss' S70... We've replaced the cat all the way to the tail pipe, both O2 sensors, and even worked on the hoses around the turbo. Basically there's a bunch o' new parts we've installed (ALL volvo cert'd parts!) And we now have this code, too. "P0422 - Main TWC efficiency Bnk1 below thresh" All codes were cleared, then after approx 57 mi the code appeared. We're a little stumped and going clear it, see if & when it comes back (accelleration, even driving, etc), and then re-check all the connections before the upper O2S before we move on. I'll keep ya posted & I hope you do the same! :grin:
Don't let the dealership work on it unless they level with you. Make sure you show them you know what the heck you're talkin about. Lay down the rules: you won't take crap from them, you won't pay for their screw ups, & you expect complete honesty. They throw whoever's available out there to talk to you even if it's a new guy that hasn't finished his Volvo cert mech course. (Almost all the car dealers do this, not just volvo.) If the mech says "I don't know," then the boss is gonna get MAD, cause they want people to think ALL the mechs back there know everything there is to know about the cars they service. I get a lot of crap from them with my GMC because I'm a chick, but once I call their bluff and start talkin shop with them it's good to go. :thumbsup:
After an alignment my front passenger wheel felt like it was gonna come off while I was driving, but when I checked the lug nuts, they were tight. I brought it back and told them to fix it. They claimed they didn't do it, and that it was someone else since they don't touch the fixtures attaching the wheel assenbly in an alignment! I went off on them and rattled off how the entire wheel-well area is assembled and the location of the alignment bolts. He got embarassed to be caught in his lie by a (very pregnant) woman, and I got it all fixed free. It knocks them off balance and then they're trying to show they know more than a girl! I love it - it's gives me something to laugh about the rest of the day! :bwekk:
tr_car_nut
post Sep 1 2008, 12:21 PM
Drives: 2003 Volvo S40, 1997 Volvo 850 (non-turbo)
My mother in-laws 2000 V70 XC has the CEL on recently (just when I happened to drive it). The car has been sitting since she has been ill so not much driving of that vehicle. The car has a little over 88K and I ran the codes at Advance auto and I received the P0422. I believe this is the second time the light has come on in the last year. Advance Auto thought it might be the O2 sensor instead of the Catalytic converter but only a guess. She will be taking it to a local mechanic who specializes in Volvo's to have it checked. BTW I'm also in NC.
MechChick
post Sep 9 2008, 08:19 AM
Drives: GMC C3
Since the last post (SIGH!) we cleared the code, then replaced the water pump. So far the code hasn't come back and it's been over 90 miles later. :amen: We'll see if it stays that way. Not sure what made it stay away... :huh: Maybe a combo of all of the above!! :beer:
raydar
post Sep 9 2008, 04:25 PM
Drives: 2007 s80 d5
hope its not a cheap aftermarket cat you fitted mechchick as unfortunatly this can also be a cause of this code as the cat is not efficient as a oe part and can take to long to get to operating temperature and function as well as a original part (had this on a s40).
FromLeftField
post Sep 22 2008, 02:30 PM
Drives: 2000 XC70 and 2000 V70
I have been chasing a P0422 on my 2000 XC70 (140K miles) for a few months.
I may have finally resolved it in the past week.
It was an obtuse, but inexpensive problem to fix.
My approach was to eliminate all the places where un-metered air could get into the intake manifold.... clean and clamp the vacuum hoses; etc.
After checking and rechecking everything, and making some significant improvements in the performance and economy along the way, I still got an occasional P0422 under specific driving conditions.
One more check last week and I discovered that one of the two plastic clips on the intake air temperature sensor was broken off.
I bought a new one from volvo for about $20. It took 2 minutes to replace.
With only one plastic clip, the sensor will work fine at highway speed and a good vacuum in the intake. At suburban driving, the seal is not so good, and a positive pressure in the intake (like when you let you foot off the gas), might even push the sensor partially out.
IMHO, the only way that sensor got broken was when it was in the dealer for service. From the looks of the break, it has been broken for a while.
I think that this solution to P0422 would more likely apply to turbo vehicles, as the non-turbo's would not have the positive pressure in the intake.
Good luck !
T4 Engine Problem
nickfev 74 2 Oct 9 2008, 03:46 PM
By: bushytale
Srs Light Wont Go Off
XK150 23 0 Oct 8 2008, 08:37 PM
By: XK150
Fastest Engine For 240
duffy 125 6 Oct 8 2008, 04:12 AM
By: Volgrrr
How Do I Reset "brake Failure" Light?
PHYVOLVO 424 10 Oct 8 2008, 04:08 AM
By: Volgrrr
S40 Engine
resevil 111 2 Oct 8 2008, 02:19 AM
By: S40guy
Time is now: 13th October 2008 - 04:59 PM
