> Bushing Replacement At 51k Miles?
l_e_miller
post Feb 21 2008, 08:15 PM
Drives: S40
Ok the dealer said that my suspension sway bar/bushings needed replacement ($430 quote). The bushings are rubber, I understand that they would wear down over time. He stated that the car is pulling left a bit and it could be an axel problem, could be suspension sway bar/bushing, etc. BTW, the car is making no noises in regards to the suspension. I'm thinking this is an early sign but it probably does need to be replaced. Absolutely nothing major that I've noticed.
2001 S40, 51K miles, never driven hard or for very long distances. My father thinks this is bull and that 51K is very low mileage for bushing replacement.
Yeah, I'm a chick but I'm not an idi*t. I take good care of my car. But I don't want to be screwed over ;-)
Comments, suggestions? Thanks so much!
S40guy
post Feb 23 2008, 11:54 PM
Drives: 2004 Volvo S40
When it comes to bushings time causes more wear than mileage sometimes. However I don't see why that would make the car pull to the left. Pulling to the left or right is most commonly caused by tires.
I would try rotating the tires from front to back and see if you still have a pulling problem before spending money needlessly on parts. My car is VERY sensitive to tire pull. When I first bought my car it pulled and I ended up rotating the tires every way possible until I finally found the perfect rotation. I had pull to the right, rotated and ended up with pull to the left, finally on the third tire swap combination I found it to drive perfectly straight.
You may also find that many tires cause a lot of noise on these cars that can be mistaken for bad wheel bearings. I found a website that suggested you avoid running tires with a block style tread pattern. I guess it's just a suspension design issue. My original Michelin tires were so noisy I hated driving my car.
Good luck!
Remote Case Replacement?
roe1352 79 3 Aug 30 2008, 09:33 AM
By: roe1352
How Many Miles/km Do You Have On Your Volvo740?
ClayKuch 2,367 45 Aug 24 2008, 10:01 PM
By: driveforlife
240 Wagon Antenna Replacement
Teenonator 443 9 Aug 20 2008, 01:27 AM
By: Teenonator
Brake Booster Replacement
Tech 982 3 Aug 19 2008, 07:19 PM
By: kbiski
'01 V70 Rear Wheel Bearing Replacement
meinriver 103 0 Aug 11 2008, 05:05 PM
By: meinriver
Time is now: 6th September 2008 - 02:05 AM
