> 1990 240 No Pump Relay Clicking, Non Starting
throweasy03
post Feb 20 2008, 08:05 AM
Drives: 1990 Volvo 240
Hi, I thought I had a fuel pump or filter problem because of non starting. I removed the filter, it was clogged and I changed it but car still wouldn't start. I changed the external pump next. After changing the filter and external pump I noticed the fuel pump relay won't click anymore when I turn the key on. I changed it with a spare, I knew both relays to be working. Now there is no relay clicking when the key is turned to on position. I know when you turn on the key, the pump relay is supposed to click for a few seconds which tells you it is working and good. After I wired in the new pump the relay won't click anymore. I am sure the polarity is correct. What might cause the relay to stop working after installing a new pump? Thanks
jks2
post Feb 20 2008, 08:13 AM
Post moved, member notified.
post Feb 20 2008, 10:28 AM
Inspect and clean fuses 4 and 6. Check for +12v on terminals 30 and 85 of the fuel pump relay when the key is in the on position.
throweasy03
post Feb 24 2008, 07:07 PM
Since I installed the new pump the fuel relay won't click any more (I tried two known to be good) instead when I turn the key on there is a constant fairly loud clicking coming from under the engine hood. Besides the negative and postive terminals on the fuel pump itself, are there any other electrical connections that I may have missed or forgotten to put back on? what might clicking from under the hood be when the key is on the :on" position? I checked fuses 4 and 6 in the fuse panel and also the 25 amp fuse which hooks up to the positive terminal of the battery.
post Feb 25 2008, 10:32 AM
I would inspect/clean all of the fuses, then try to isolate where the clicking is coming from.
volvoocrunch
post Feb 28 2008, 08:36 AM
Drives: 1988 volvo 240
having similar problem with 88 240. and had problem a couple of years ago, which was a loose connection at the coil. the ecu needs tachometer type input to complete a ground circuit in the pump relay. follow the test procedure for the relay in the Bentley manual. best thing would be the official Volvo manual. does anybody have official volvo wiring diagrams? the common trouble points for no current to pump(s): fuses, relay, ecu, coil connection.
good luck, volvoocrunch
post Feb 28 2008, 11:57 AM
Here are two diagrams for both the ignition and fuel systems. These only generally apply to US model 240's from 85 to 88 ...
throweasy03
post Mar 1 2008, 08:38 PM
Thanks Robert, My car is a 1990. You say these are for '85 through 88. I think the Haynes manual has these diagrams. I wondering if a bad ECU 0 027 400 169 if bad could cause there to be a clicking sound from the engine when the key is in the on position. Also I noticed that my battery is fairly weak. After charging it I only get a few good cranks out of it before it starts cranking slower and slower. Could a weak battery cause strange things to happen? Can the ECU be tested if removed? Thanks
post Mar 3 2008, 10:43 AM
Definitely a weak battery could cause these issues, clean-up the cables and have the alternator tested to make sure its charging.
volvoocrunch
post Mar 6 2008, 02:17 PM
thanks for wiring diagrams
volvoocrunch
5 elmwoodblues 18 Yesterday, 09:56 PM
Last post by: elmwoodblues
4 ScruffeeBear 45 14th November 2008 - 10:33 PM
Last post by: walrus108
No New Posts Normal Temp Gauge Behaviour?
1 CJT156 254 10th November 2008 - 08:37 PM
Last post by: gobies
No New Posts No Blinkers Or Break Lights On My 1970 Volvo 142s
0 jittest1 8 10th November 2008 - 08:11 PM
Last post by: jittest1
No New Posts No Breaks, New Pads Rotors, No Leaks
4 stevet 30 10th November 2008 - 05:48 PM
Last post by: stevet
Time is now: 19th November 2008 - 08:37 AM
