> Lights Dimming
SEASEV
post Feb 6 2008, 11:37 PM
Drives: 1998 Volvo C 70
Volvo 1998 C 70
when start the car in morning all the dash lights are dim and until i put my foot on the gas then it brightens up like it should be and the interior light knob is all the up to the max also if the radio is up loud all light on the dash dim from the bass like a juke box or something like it pulling to much power is this from the battery or is a alternator problem or is something else.
rschleicher
post Feb 7 2008, 01:41 PM
Drives: 2007 C70
QUOTE(SEASEV @ Feb 6 2008, 11:37 PM)
Volvo 1998 C 70
[right][snapback]71681[/snapback][/right]
Yes, it could be an alternator problem. If you have access to a voltmeter you can do some crude checking by just looking at the voltage on the battery terminals with the car at idle, and then with someone revving the engine slightly. The voltage with the car running (with most cars, anyway) should be somewhat over 13.5 volts, and shouldn't vary too much with engine rpm. It will be a little lower at idle, but not that much. You also might try turning on and off various accessories, including the stereo, with the car at idle, at revved a bit. (Note that the battery voltage with the car off will be more like 12.8 volts or thereabouts.) If the voltage at idle is less than 13 volts, then it is probably an alternator issue.
If you have recently installed something like an aftermarket amp, or some other non-original accessory, then it may also be a case of too much total current draw for the stock alternator at idle.
post Feb 7 2008, 06:09 PM
Good call from rschleicher. +1 from me.
torkk
post Feb 15 2008, 05:01 PM
Drives: c70
I have the same issue in my 01 c70. I have to get a look at it, and I think my warranty should cover it
raydar
post Feb 17 2008, 04:36 AM
Drives: 2007 s80 d5
Sometimes when you check the voltage it can be high (14.5 V +) and this also shows that a alternator is not operating correctly. Ie sometimes when the interior lamps pulse its because they are getting to much power (going over bright) and not actually going duller than usual. Just thought a would throw that in the works.
Anyhow most likley alternator at fault, common symptom.
No New Posts Lights On Shifter
Burnt out or not
2 banderz777 103 15th September 2008 - 09:39 AM
Last post by: EdinDC
No New Posts Lights Keep Burning Out
3 KevinWWFG 119 22nd June 2008 - 03:58 AM
Last post by: StewartM
No New Posts Lights Acting Weird
HELP!
4 kevroh06 280 22nd February 2008 - 06:42 PM
Last post by: superbeetlejosh
No New Posts Lights Dimming
ut oh
4 neomaxim 182 24th January 2008 - 06:30 PM
Last post by: Volgrrr
No New Posts Lights: Check Engine, Abs, Tracs, W, Srs
warning lights going on
5 caldweja 2,368 20th August 2007 - 08:55 PM
Last post by: llama_of_doom
Time is now: 19th November 2008 - 07:10 AM
