3 Pages < 1 2 3 >
> Instrument Cluster Light, orange box green triangle
post Feb 10 2008, 05:28 PM
Post #21
hey, i still think that your car come with the half-life game already installed and am very jealous :grin:
love2hatemy850T
post Feb 11 2008, 08:23 PM
Post #22
Drives: '95 850T
Ya, I would be a happy man if it just passed half-life with 320 on the clock. The light hasn't been back. Trying to figure out what was different about the day it came on. I did whack the top of the dash a couple times and some of my general lighting bulbs came on for the cluster.This has me wondering if the damn light is on all the time and just not making the connection always. Well i will see if it will give me any codes. Cheers.
P.S- Just replaced my front wheel bearing, two bolts took me 4 hrs. Ya know, strip,chisel and cut !!
post Feb 12 2008, 04:56 PM
Post #23
wooooohoooooooooooo, heavy tools. nothing like banging the crap out of something with a heavy tool. hey now, get your minds out of the gutter :grin: , what you think everybody is greek? :lol:
gatesofrequiem
post Mar 26 2008, 05:13 PM
Post #24
Drives: 1996 volvo 850
thanks greek. check out my new topic!
seanmc87
post Mar 26 2008, 09:33 PM
Post #25
Drives: 1996 850 T-5
old topic but since its already been bumped....
yes this is def check engine light for euro cars as it is the one on my car and also is in my manual.
sean
post Mar 27 2008, 01:46 AM
Post #26
QUOTE(love2hatemy850T @ Feb 6 2008, 10:36 AM)
[attachmentid=3662]Hey fellas, the infamous light has not returned so i drew a picture. Correct me if I'm wrong but it is my belief that upon turning the key to the II position all of the instrument lights should come on and the computer does an onboard diagnostics or "system check" before ignition begins in the next position. The box in that space has never lit up before-not position I-not position II- not upon starting.The strange thing is , for the short duration that this light entered my life it came on upon position II with the rest of the lights in the system check mode.This has never happened before and now once again is just a dead space. The car started as normal with the ABS and TRACS lights staying on and then upon hitting the brakes "POOF" the unknown light was on. I am going to have the hydraulic unit rebuilt to hopefully cure my ABS. Has anyone else seen this light before?
I hope you guys are OK, here.
Anycase, lovetohate, even if the light has shut out, without a proper deletion using either the obd1 box in the engine bay or the code reader for the obd2 systems, the message will still be in the memory. You can still use the code-reader to retrieve and see what message lies within that caused the lambda light to emerge in the first place.
Thanks.
850_newbie
post Mar 31 2008, 12:16 PM
Post #27
Drives: Volvo 850 T5
QUOTE(seanmc87 @ Mar 27 2008, 10:33 AM)
sean
this is the EES right? something to do with fault on the engine fuel or ignition system (says in the manual) this also means that the engine does not meet exhaust regulation?
just to cut things short mine is on. half life sign is the check engine for eu V's right?
but when i got home this evening the light turned off. maybe something to do with the brand of unleaded gas i use? BTW engine starts normally.
post Mar 31 2008, 10:20 PM
Post #28
QUOTE(850_newbie @ Apr 1 2008, 01:16 AM)
The lambda light could be triggered by a few possibilities. And after a while, they will reevaluate the problem, and if the problem has been taken cared of, or is fixed, then after a 'few cycles', the light will go off. But the message will continue to be stored, until you manually delete it. Which is why it is best to attack the problem when the light is still on. Cause, if you keep accumulating the error messages, you wont know which is the actual problem once you retrieve everything down.
THanks.
850_newbie
post Apr 1 2008, 02:41 AM
Post #29
QUOTE(ampangbear @ Apr 1 2008, 11:20 AM)
THanks.
how to delete?
post Apr 1 2008, 10:20 PM
Post #30
I think My Man Greek asked you a question earlier about the year of manufacture for your 850.
The reason is just that pre1995 manufactured 850s run on the OBD1 system, and you can read/delete error codes from the small black box located between your ECU box and the front headlights.
But post 1995 850s are OBD2 system, where you'll need a code-scanner or a scan-tool to read the codes and delete etc. The usual typical case is that the more expensive the reader, the more functions it carries. Try googling up if you want to buy any.
Aside from that, either go to the accessories store (Greek mentioned Pep-Boys?) or the dealer to get them to help read and delete the codes.
Let's hope its just something small.
850_newbie
post Apr 2 2008, 01:17 AM
Post #31
QUOTE(ampangbear @ Apr 2 2008, 11:20 AM)
its a 96 with obd2 socket.
post Apr 2 2008, 11:13 PM
Post #32
Thanks and cheers!
EDWAR983
post Apr 15 2008, 06:15 PM
Post #33
Drives: 1994 VOLVO 850 2.0L SALOON & 1994 VOLVO 940 2.3L ESTATE
HI OVER IN THE UL IT IS KNOW THE LAMBDA LIGHT OURS CAME ON WHEN IT WAS RUNING LIKE A BAG OF ***, SORTED IT AND THEN SWITCHED THE LIGHT OFF MYSELF WHICH WAS EASIY PEASEY. IF YOU NEED TO KNOW HOW TO SWITCH THIS OFF PLEASE EMAIL ME TO DO THIS AS I CAN SWITCH IT OFF FOR MOST VOLVO'S WELL YOU CAN SWITCH THE LIGHT OFF YOURSELF.
HOPE THIS HELPS MANY OF YOU PEOPLE OUT THERE
850_newbie
post Apr 21 2008, 12:51 PM
Post #34
QUOTE(EDWAR983 @ Apr 16 2008, 07:15 AM)
how to switch it off? PM me please. thanks!
post Apr 24 2008, 01:23 AM
Post #35
I think Edward983 is running on OBD1 system, with the small-black box in the engine bay.
850_newbie
post Apr 30 2008, 12:57 AM
Post #36
how bout with obd2? can i still turn the lamda light off?
Ryan 20
post Apr 30 2008, 01:42 AM
Post #37
Drives: 1984 Volvo 245 DL
Besides using a OBD II scanner you can unhook the battery but you shouldn't do that until you know why the Check Engine / Lambda light turned on (IE) read the codes with the scanner first.
post May 1 2008, 07:02 PM
Post #38
it won't go off by disconnecting the battery, it will come back if it's something that needs to be looked at.
post May 1 2008, 09:21 PM
Post #39
Yes, for the OBD2 systems, you need to use a scanner to read the codes. Many versions are available on the Net. Just make sure they can read Volvos, on top of the universal codes and you should be fine.
And read them, and rectify the issue first, and THEN, delete the code.
julin
post May 8 2008, 08:44 AM
Post #40
Drives: VOLVO 850 T5
hi about orange light
is the car left or rihgt hand drive
im in UK the light is for the( lamda sund )
system
one way to get riof it possibley is disconnect batty and wait two minutes
make sure you have the radio code first
then reconnect, light might go out when running if not you will need to replace sencer in the exhaust
3 Pages < 1 2 3 >
