> 1993 240 Wagon - Wipers Only Work On High
Lyle_s
post Jan 27 2008, 03:59 PM
Drives: 1993 Volvo 240 Wagon
Hi all,
I bought a 93 240 wagon a few months ago. The rear wiper has never worked for me but I never took the search any further than the fuse, which appears to be OK. Anyhow, a couple of weeks ago the regular wipers stopped working, as well. Except, they still work if turned on high! Regular speed and intermittent, I get nothing. If I have them on high and then switch to the lower speed, the wipers stop dead in their tracks.
I'm a novice when it comes to fixing cars (or anything) but I always like to give it a try. I'm reasoning that the behavior points to the switch itself. Does that sound correct or should I be starting somewhere else?
Thanks!
Lyle
post Jan 27 2008, 08:46 PM
sounds about right. but both the front and rear are doing them at the same time? that's weird.
Lyle_s
post Jan 27 2008, 08:52 PM
Hi and thanks for your reply, GreekMason!
I probably didn't word my post very good. Rear wiper doesn't work ever, front only works at the highest setting.
jjnuttall
post Jan 29 2008, 07:30 AM
Drives: 1989 240 DL Wgn, 5spd, 300K+
FYI:....rear wiper issues may not be related to the "stalk" at all...could be issues with the rear wiring harness that passes through the tailgate hinge...
Lyle_s
post Jan 29 2008, 09:56 PM
Good point. At this point I'm just thinking fix the switch to deal with the front and if the rear is not fixed, keep plugging. I've suspected there might be an issue in the back as the rear defrost works poorly, if at all.
If I'm looking at something to do with that harness, would that be a costly repair?
claudeworld
post Jan 30 2008, 07:36 PM
Drives: 1986 Volvo 240 DL
These words are not from an expert, nor someone well-versed in auto mechanics, but... Just beware--recently (on an '86 240DL) had a rear defogger fixed. After that, alt. light likes to come on at beginning of day (though the steering became smoother!!-go figure). Never did before. Also had a new front wiper motor put in. It squeals often when warming up car like it's being "taxed" or it's taxing something else. Meanwhile, the good news: my last harness issue was a breeze.
claudeworld
post Jan 30 2008, 07:39 PM
Oh yeah, I forgot. The wiper motor was replaced because wipers worked on everything BUT high.
jjnuttall
post Jan 31 2008, 08:11 PM
QUOTE(Lyle_s @ Jan 29 2008, 10:56 PM)
[right][snapback]70968[/snapback][/right]
nope, about 40 bux a side for OEM harnesses from iPd
(IMG:http://www.ipdusa.com/uploads/images_skus/2560.jpg)
http://www.ipdusa.com/product.asp?strParents=&CAT_ID=0&P_ID=1320&strPageHistory=search&numSearchStartRecord=1
Lyle_s
post Jun 18 2008, 10:18 PM
So, it's been a while but I finally replaced the wiper switch after the front wipers quit working altogether (it's been a couple of months since they last worked on the highest setting, which was the only setting they worked on!).
Unfortunately, no change. Rear wiper doesn't work and front wiper doesn't work on any setting.
Any suggestions on what to try next?
post Jun 19 2008, 05:34 AM
get a torch, pref >=6V. disconnect the wiper wires and reconnect it so that the lamp, the battery and the wiper motor are daisy-chained together electrically. swith lamp on observe lamp, then disconnect one wiper wire and connect the previously spare one.. Your are looking for the lamp glowing differently on the different windings, thus demonstrating that it is ok. I THINK there's a timer circuit somewhere for the intermittent wiper action, but I don't KNOW anything about it, there may even be a relay associated with it. the wiper motor prob has a contact board with at least 2 segments and a wiper on it the longer broken segment is live whilst ign on. the shorter one becomes live when the wiper is on With the wiper switch off, it should park with the short segment under the wiper. dead, but connected between wiper and arc. They provide the switching of the power from the initial start arc to the end of the return of the sweep. Bad connections here will prevent it working, and a poor connection will get hot, whilst no connection will remain cold. The heat mentioned tends to destruction. Bad connectors and switches are normal for older cars too, even failed wiring can occur. segments should not spark whilst operating.
Lyle_s
post Aug 27 2008, 10:58 AM
Hey everyone, so I finally gave up and took the car to my mechanic. I'm embarrassed to say that the connector to the wiper motor had wiggled itself all the way off. He reconnected it and it works fine. Rear wiper still doesn't work but I'll replace the wiring harness one of these days as it looks freyed/severed.
Thanks to everyone who gave advice!
-lyle
9 physicalgorilla 106 Today, 11:01 AM
Last post by: robert240
5 dlm423 49 17th November 2008 - 02:49 AM
4 ScruffeeBear 51 14th November 2008 - 10:33 PM
Last post by: walrus108
No New Posts Topic has attachments1993 850 Electronic Climate Control
ECU failed?
5 milstarchuck 29 11th November 2008 - 11:14 PM
Last post by: swedseed850
7 Spark 1234 95 9th November 2008 - 08:08 PM
Time is now: 20th November 2008 - 01:43 PM
