> Location Of Thermostat And Temp Sensor, thermostat & temp sensor: 2002 S40 1.9L
gonzalobriceno
post Jan 24 2008, 02:18 PM
Drives: 2002 s40
Could someone please post a picture showing where the thermostat and temperature sensor are located (preferably on a 2002 S40), otherwise, I will post a pic and you guys point it out.
From what I see online, the thermostat is NOT the same as the cap that closes the coolant reservoir. I am referring to the black cap that is located as close as you can get to the passenger within the engine compartment (have a look, pic of 2001 S40 engine compartment, the cap is above the left side of the strut tower bar).
If you have any resources with clear illustration of various sensors and such please forward them to me.
mcoles
post Jan 24 2008, 06:56 PM
Remove splash guard from under the engine bay, at the bottom of the radiator on the left when looking into the engine bay you'l find a tap. Open tap and wait for the coolant to drain out.
Undo the bolts that hold the thermostat cover, engine end of the pipe that goes from the radiator to the engine block, left of the exhaust manifold when looking into the engine bay. You'll find the thermostat there, change for a new one and put the hose back.
Close tap at the bottom of the radiator, put the splash guard back.
Fill the reservoir, turn the engine on and continue to topup the reservoir as the water circulates through the system. Don't forget to turn the radiator to full heat inside the car.
Takes about 15 minutes before system full again using this method, just remember to monitor coolant levels for about a week.
gonzalobriceno
post Jan 26 2008, 02:03 PM
Drives: 2002 s40
Thank you very much for your reply. Although you clearly explain where the thermostat is located, would you mind verifying that the image attached does indeed point to the correct area? Thanks a million...
fullofquestions
post Jan 26 2008, 07:44 PM
Drives: 2002 S40
Your picture looks about right. Have a look at the following site for a similar how to.
http://www.matthewsvolvosite.com/tstat.php
Does anyone agree that the S40 thermostat is located where the picture above points to?
No New Posts Temp Problem
idle, starting, hot
2 ircaptbob 83 8th October 2008 - 06:29 AM
Last post by: ircaptbob
No New Posts Location Of Spark Plugs?
1 drifter2130 150 26th September 2008 - 02:37 PM
Last post by: jks2
No New Posts Location Of Maf Sensor?
2 BimmertoVolvo 334 20th September 2008 - 02:02 AM
Last post by: BimmertoVolvo
No New Posts Pinned: Of Engine Oils
Recommended Readings
6 ampangbear 1,700 24th August 2008 - 03:27 AM
No New Posts Temp Gauge Sender?
where is it?
1 heribertorosas 232 16th August 2008 - 07:55 PM
Last post by: danr960
Time is now: 20th November 2008 - 01:04 PM
