> Rough Idle
alex21
post Jan 16 2008, 05:54 PM
Drives: volvo v40
just had my R reg 1998 V40 serviced with other bits done to it. its a 1.8 xs. before i got it serviced it was runing like a dog. mainly the idle. if you took your foot off the accelerator it would drop to about 400 rpm and then bounce back upto 900.
the car has 197k on the clock
the problem is now, is its still doing it but its going up and down and up and down. also there seems to be white smoke coming out the back. ive not used the car in 4 months or so and i assume thats water vapour from the exaust. what could the problem be? ive thrown in some redex to try and rectify the problem.
thanks
Alex
mcoles
post Jan 16 2008, 06:48 PM
Try cleaning out the throttle body and idle control valve with throttle body cleaner after disassembly
alex21
post Jan 17 2008, 01:50 PM
Drives: volvo v40
thanks for that infomation so it is true then. so do i just take the TB to bits and clean it all? i assume the idle valve is within the TB yep?
thanks very much for your help
mcoles
post Jan 18 2008, 04:46 AM
Has 2 bolts holding it onto the side of the tb.
alex21
post Jan 22 2008, 12:32 PM
Drives: volvo v40
hi there mcoles. i took air filter off and all the piping and the TB was on with 4 bolts. unfortunately for me i couldnt find my socket set. ive found it now but its too dark to do it. the TB is held on with 4 bolts, is this normal? i have the mitsubushi engine in there
mcoles
post Jan 22 2008, 07:19 PM
Hi, you were asking about the idle control valve which does need to be removed to be cleaned, using the 2 bolts mentioned previously. As for the throttle body I left it attached to the block and squirted cleaner into it and used a jay cloth to clean. Just note that you may need to crank the engine a few more times before it starts if you clean in place.
alex21
post Jan 23 2008, 11:02 AM
Drives: volvo v40
yeah i wasnt going to remove the TB, but i cannot see the valve on the engine? there is a wire going to the top of the air box, but when you look in there, there doesnt seem to be a valve.
i suppose i should have mentioned this before, i do apoligize, i was trying to follow this link!
http://volvospeed.com/vs_forum/lofiversion...php/t73651.html
i have the mitsubushi engine. my engine doesnt look like that unfortunately, and as im not too mechanically minded im a bit stuck. i just have an airbox, bit of piping, then traight into TB. is this right?
thank you ever so much for your time so far
alex21
post Feb 3 2008, 08:14 AM
Drives: volvo v40
sorted it out. sprayed a shed load of carb cleaner down the 2 little holes in the throttle body. about half inch inwards at the bottom. i couldnt undo the rusted screws to take the AIC off. i used cotton buds to soak up and rub inside the aic. worked a treat.
thanks for all your help mate.
Black Smoke, Rough Idle On '99 S70
garlinto 23 1 Yesterday, 05:14 PM
By: garlinto
1999 S80 T6 Idle Problems Again
draco 47 3 Aug 31 2008, 07:20 PM
By: draco
Volvo 850 Dying After Idle
youngvolvoowner 31 3 Aug 31 2008, 01:38 PM
By: youngvolvoowner
Rough Under Heavy Accelleration
VAVolvoDriver 108 19 Aug 25 2008, 08:37 AM
By: woodsytf
Engine Running Rough
trevortrumpet 77 2 Aug 17 2008, 06:47 PM
By: epereira
Time is now: 4th September 2008 - 11:28 PM
