> Need Help With Cruise Control System
blakbyrd
post Jan 14 2008, 04:35 PM
Ever since I bought my 1995 Volvo 850 Turbo Wagon (5.3L engine) the cruise control has not worked.
I have yet to be able to determine what may be causing it not to work. Below are the items I have replaced, followed by a list of what I have looked for in regards to this problem.
Replaced:
Cruise Control Relay (the cruise module?)- located under fuse box
Cruise Control Air Pump - Located under battery
Cruise Control Stalk (left side of steering wheel)
Looked for:
Cannot hear any activation of the cruise control relay
Cannot hear any activation of the cruise control pump
Does anyone have any suggestions on what to check next, or a list of the other parts that are part of the cruise control system? A with many 850 problems, there tends to be common things to look for (IE. bad odometer, check the odometer gear...Starting problem, check the fuel pump relay, etc). Is there anything common to go wrong with the cruise control system on an 850?
I have not yet checked the brake pedal switch for the cruise system, but it is next. Aside from that, what other parts are there for the cruise control system.
Thanks all.
post Jan 15 2008, 04:11 AM
QUOTE(blakbyrd @ Jan 15 2008, 05:35 AM)
[right][snapback]69750[/snapback][/right]
USUALLY, the vacuum lines leak, causing the issue with the cruise control.
blakbyrd
post Jan 15 2008, 08:35 AM
Can you give a basic idea of how extensive the vaccum llines for the cruise system are? Or is is just 2-3 lines to inspect? Or by chance, if a leak happens to be the culprit, could it be caused anywhere in the vaccuum system?
Lastly, is there a standard type of vaccumm line throughout the car, so that one could simply purchase a roll of tubing and replace all the lines in the car, without having to try to purchase multiple lines from the dealership?
Thanks again.
70 140
post Jan 15 2008, 01:55 PM
Drives: cars
QUOTE(blakbyrd @ Jan 14 2008, 04:35 PM)
5.3L ? Is it a V8 Conversion?
blakbyrd
post Jan 15 2008, 02:53 PM
Haha...oops, bad typo there (although it might be fun to have such a conversion, sadly mine isn't).
It's the 2.3L
Or maybe the cruise doesn't work because half the engine is missing. :P
jks2
post Jan 15 2008, 03:19 PM
You know I think I saw half an engine laying on the side of the road last week. If I had known it was yours I would have picked it up. :grin:
blakbyrd
post Jan 15 2008, 05:04 PM
QUOTE(jks2 @ Jan 15 2008, 04:19 PM)
[right][snapback]69822[/snapback][/right]
My father actually had the engine fall out of his car once while on the interstate...that was interesting.
At least that's the best way he could describe it. It was still connected to the transmission, but the engine mounts broke and dropped the block to the pavement.
post Jan 20 2008, 03:15 AM
QUOTE(blakbyrd @ Jan 15 2008, 09:35 PM)
Thanks again.
[right][snapback]69799[/snapback][/right]
Actually yes, the diagram is in this forum. If you could run a check, i know it's a lot of the archives to go through, but i am confident it is here somewhere.
Volgrrr
post Feb 20 2008, 12:04 AM
QUOTE(blakbyrd @ Jan 15 2008, 08:35 AM)
Replaced:
Looked for:
Thanks all.
Just happened to come across this post and here is one more thing to consider.
It might be worthwhile checking the cruise control vacuum valve which is operated by the brake pedal (it is a little black cylinderical thing sitting up near the top of the brake pedal). It's specific purpose is (if you are travelling along in cruise control mode) to get rid of the vacuum if the brakes are operated and consequently the cruise control will drop out immediately.
All cars have this type of safety overide.
Therefore, if this insignicant little valve goes faulty your cruise control stops working - and you won't be able to get it going until the faulty valve is replaced.
:57: :57:
ote]
post Feb 25 2008, 09:34 PM
Thats a good one, Volgrrr...
Volgrrr
post Feb 29 2008, 05:07 AM
Replaced:
Looked for:
Thanks all.
Have you found the problem yet?
name that sensor?
3 Martyn2112 26 Today, 01:10 AM
Last post by: ampangbear2
oil everywhere! Cam seals?
17 swedseed850 75 Yesterday, 04:21 PM
HID WARNING LIGHT
3 bikz 224 Yesterday, 09:35 AM
Last post by: bikz
Need info on where to start
3 Jenny Z 20 18th November 2008 - 03:26 AM
Last post by: Doogwhan
No New Posts Help 940 Will Turn Over But Won't Catch
3 jbowers 34 15th November 2008 - 01:28 PM
Time is now: 20th November 2008 - 10:39 AM
