> Engine Cuts Out, Engine Cuts out
KUL
post Dec 17 2007, 12:32 PM
Drives: 2003 Volvo C70 T5 Convertible
Currently have a problem that occurs randomly as it occurs when the engine is hot or cold, but it doesn't always happen.
When I start the car, the engine will start, but within a second it will cut out. this will happen even if I leave my foot on the accelerator slightly or if I try to rev the engine during the initial start up.
Once the engine cuts out, it normally takes a while to start the car as the engine turns over, but does not fire up.
Has anyone got any suggestions
afgable
post Dec 26 2007, 04:59 PM
Drives: 2004 Volvo C70 2.4 LPT
My car, a 2004 C70 LPT is doing the same thing. I can drive from work to a grocery store in my neighborhood (approx. 10 miles), then when I come out of the grocery store 30-45 min. later, the car won't start.
The engine turns over but won't fire up. It doesn't do this all the time, just random. When I take it to the dealer, it hasn't stored any codes and because the behavior is so random, they can never re-create the problem. I'm taking it back to the dealer on Friday -- it was delivered "late in life" and is still under warrranty.
I am at my wit's end with the situation -- hopefully someone will post something to point us in the right direction.
Any ideas?
raydar
post Dec 27 2007, 01:13 PM
Drives: 2007 s80 d5
Sounds like a immobilizer fault. Very common on this model, a code ecm-720a no comms fault is usually recorded in car. slightly bending/tightening immob antenna connector pins and immob control module pins fix this fault. I would do this before even cosidering any further tests/fault trace as most likly the problem.
afgable
post Dec 28 2007, 03:45 PM
I just got off the phone with my service advisor at the dealership. It was an immobilizer problem, as raydar suggested. The mechanic found that the antenna connectors were going bad and replaced them. So now, the computer should recognize my key every time.
KUL -- good luck with your car!
KUL
post Dec 29 2007, 06:40 PM
Thanks, i'll take the car down for them to take a look, how much did they charge, or does anyone in the uk have any idea of costs
efftee
post Apr 21 2008, 06:56 AM
Drives: 2001 volvo c70 t5
Hi I've been having the same problem, can you tell me where the immobilizer is situated?
Thanks.
ajmustafa
post May 5 2008, 05:14 AM
Drives: C70 cabrio 2001
where is the imobiliser and antena located pls any one as I also have this annoying problem
KUL
post Jun 17 2008, 04:16 PM
I bought a new Immobiliser Antenna from Volvo and fitted it, took 10 minutes to do, all you have to do is remove the casing around the steering column and then un-clip the antenna from one side with a screw driver (be careful as the wire next to it goes into the airbag). Once the antenna is off all you have to do is unplug the old on and then fit the new one, and that it. The keys don't need to be reprogrammed.
Hopefully this has fixed the problem, but I guess time will tell.
Dismantling Engine, Need Some Advice
bakern 179 21 Today, 12:56 AM
By: rosso75
Engine Won't Start When Warm
bakern 4,211 99 Yesterday, 10:23 PM
By: bakern
Flashing Map Lights/ck Engine
smhcine 177 18 Yesterday, 02:04 AM
By: Volgrrr
Engine Stalling
MarkF 16 0 Jul 16 2008, 05:14 AM
By: MarkF
Changed The Engine Cradle On The 850
effdbmx1 65 12 Jul 15 2008, 11:23 AM
By: effdbmx1
Time is now: 18th July 2008 - 11:03 PM
