> Fireing Order On 940 2.3, fireing order
ttom
post Dec 15 2007, 09:58 AM
Drives: 1993 740 se wagon
hi gang well im baffeled on this one,i just did a tune up on my 93 940wagon and put in a new fire trap or pvc valve new pluges,cap.rotor,and wires.i notice that the fireing order that was on the car was odd it was 4312 and i know it should be 1342. when i put the wires in the right sopt it would not start i put them back the way they were and started right up and ran ok but it somtimes shackes.can sombody tell me whats up with this.the car is in verry good shap with only 136,000 on her thanks for eny help :liebe011:
alon
post Dec 18 2007, 09:11 AM
Drives: 1991 940 GL Manual
It looks like you are right:
http://www.wiegers-2.tmfweb.nl/Motor%20specs.htm
B230
B234 Description Used from 1985 to 1995 in the 240,740 and 940 Series
Similar design to the B21, most parts are interchangeable.
B230= 2.3litres
4 cylinders in line
Overhead camshaft engine
B200K,B230A,B230K: single carburetor version
B200E,B230E: fuel injection high compression version
B230F: fuel injection low compression version
B230FT: fuel injection turbo charged version
B234: fuel injection 16 valves version
12 Volts electrical system
Firing order 1-3-4-2 clockwise
Oil capacity with filter: 3.85 litters (8.1 US pints)
alon
post Dec 18 2007, 09:14 AM
check this out, this may be your answer:
search for "Firing Order and Reinstalling Plug Wires"
http://www.volvoclub.org.uk/faq/ElectricalIgnition.html
ttom
post Dec 19 2007, 05:20 AM
ok i did put them in the right spot on the cap 1342 and on the block 1234 as 1 being the 1st one closest to the front of the car it started but ran very bad put it back to the way it was 4312 and runs ok ???? could the timing be way off the person that i bought it from had a timing belt and water pump put on this is my fourth volvo and im realy baffeld on this i know it should not run the way the firing order is now. thanks for all your help
alon
post Dec 19 2007, 08:04 AM
go to page 4 fig. 2
http://caunter.ca/volvo960/oc14811.pdf
I have attached my 940 ignition wiring digram, I hope it can help.
mined you it's a B200 engine.
JB945t
post Dec 19 2007, 05:09 PM
Drives: 93 945t
The bosch system with the distributor mounted at the back of the head uses the firing order 4-3-1-2, The other firing order your thinking of is for block mounted distributors
ttom
post Dec 20 2007, 05:10 AM
thanks so it is right even though i have a regina coil and set up but its just strang that mu 740 that i had the firing order on it was 1342 and had the same motor in it but it just seems off beat that is 4312 but ishe runs fine thanks gang for all the help
Radio Removal From 940
whatarascal 447 6 Aug 26 2008, 09:11 PM
By: Bacci 960
Volvo 940 (1992) Radio Wiring
flightsimer 21 0 Aug 24 2008, 01:28 PM
By: flightsimer
robosteamer 53 0 Aug 18 2008, 12:54 AM
By: robosteamer
1992 940 Turbo Idles Low And Dies
courseyrn 132 3 Aug 9 2008, 05:38 PM
By: skyrider20
Resetting Volvoguard Alarm On 1995 940
PAW1212 79 0 Aug 8 2008, 04:35 PM
By: PAW1212
Time is now: 30th August 2008 - 07:59 AM
