> Perplexing Noise, At Speed (88' 240), In fifth gear, above 60mph there's a hum
bbdd12345678
post Nov 25 2007, 12:12 PM
Drives: 1988 volvo 240 DL
I've been poking around these forums for a while. Up until now, I have managed to find the help I needed by reading old posts. Unfortinantly, I could not find anything related to this topic, so I am posting.
At speed, above sixty mph, in fifth gear, my car starts to hum and sing. The noise is practically identical to the sound produced when you blow across a glass bottle--wooooohhhhh--and it only occurs under load, when I press on the gas.
I should mention that I recently had work done on the car. The clutch failed, and was replaced by a well known, (mostly) trustworthy mechanic.
Any advice--preferably comforting, because I'm broke-- will be helpful. Thanks in advanced to anyone who responds.
post Nov 25 2007, 07:35 PM
Sunroof? Any type of windscreen, etc.? Turbo?
bbdd12345678
post Nov 25 2007, 09:04 PM
There car does not have turbo, and I have inspected all the windows (there is no sunroof) as possible sources of the noise. Also, since the noise comes only at certain speeds and when the car is under load, I don't think it is related to 'wind'.
post Nov 26 2007, 09:59 AM
Sounds like a problem with the driveline - support bearing, universal joint, driveline angle, etc.
Until you have the car on a lift its hard to track down the source of the noise.
bbdd12345678
post Dec 3 2007, 07:25 PM
QUOTE
How can I tell if it is one of the above? I am able to get under the car using jack stands. I did some time ago have the support bearing replaced. How do I adjust the 'driveline angle'?
post Dec 4 2007, 10:23 AM
With a rear wheel drive car the whole rear axle wants to rotate downward with load, lowering the rear portion of the drive line. The car has torque rod and trailing arm bushings to keep this from happening, which wear out.
Does your rear differentail leak? It could be low on fluid??? Hard to tell without inspection, I would take it back to the trustworthy mechanic.
breadmeister2
post Dec 5 2007, 12:32 AM
Drives: 1985 Volvo 240 DL Wagon
I have a '85 240 dl...I had a similar issue, and it turned out to be low transmission fluid. Only when I went at highway speeds (60+). I changed out my rear transmission bushing and found the tailpiece (sic) of my transmission showed signs of abnormal wear.
Do you have any leaks (transmission)? It is easy to determine if it is the front or rear of the transmission based upon where you see fluid collect where the car is parked on a regular basis. Correcting them can be a bit of work.
Good Luck!
Breadman
8 physicalgorilla 102 Yesterday, 09:09 PM
Last post by: Dalesmailbox
4 ScruffeeBear 51 14th November 2008 - 10:33 PM
Last post by: walrus108
7 Spark 1234 94 9th November 2008 - 08:08 PM
Last post by: robert240
No New Posts 240 Mudflaps
240 Mudflaps
0 vovogrrrl 18 7th November 2008 - 01:44 AM
Last post by: vovogrrrl
No New Posts 240 Blower Motor
5 briang2ad 95 6th November 2008 - 08:46 AM
Last post by: briang2ad
Time is now: 20th November 2008 - 03:00 AM
