> Timing Belt Procedure
cadcruzer
post Sep 10 2007, 10:55 PM
Drives: 2000 S80
I'm looking for ANY info or link on the correct procedure"atleast where the cam an crank marks line up" for replacing a timing belt on a
'00 S-80 dohc. w/autoadj.
I have a boss who takes on anything. Then pass'es it off on me :liebe011:
I havent seen this car yet , he called an told"warned" me about it about 20 minutes ago, so after calling all of my resources for a manual,"which failed" i'm here
I have done several timing belts on almost every make an model, but i believe this will be my 1st 2.9 dohc volvo.
S_E
post Sep 11 2007, 08:48 AM
Not sure about the 2.9, but on the 2.8TT (most probably the same) you have to be REALLY careful taking the timing cover off, there is a plastic coolant fitting that goes through the cover and is easy to break (it's also a pain to get the hose unplugged form the fitting), the cover has to be forced far outwards to get it out. (you may have to lift the ECU cover lid off, and maybe the whole cover/box thing, and some assorted other hoses and whatnot.)
The mark to line up the crank is visible from the top, just lines up with a line, and there is marks on the coil cover that the cam gears line up with.
tensioner bit (hard to explain) that moves is meant to line up beween the two stationary bits, than turn it over by hand and readjust, then turn it over and make sure it still lines up.
then putting the timing cover back on is a pain again, as you need to line up the tabs at the bottom aswell as not breaking the plastic coolant fitting.
hope this helps, was a bit rushed typing it.
eurodriver
post Sep 11 2007, 05:47 PM
Drives: 1999 Volvo S80 T6
Check out this link: http://www.babcox.com/editorial/ic/ic60326.htm It's not exactly for the S80, but the procedure looks like it's almost identical.
Timing belt Replacement hope it helps
KEN S80 T6
post Sep 16 2007, 09:48 AM
Drives: 2002 Volvo S80 T6
I notice the site suggested the belt be changed at 60,000 miles. The S80 owners manual recommends at 105,000 scheduled maintenance. What do you all suggest? Has anyone experienced a break prior to the scheduled maintenance?
Damotu
post Sep 19 2007, 12:58 PM
:blush: I have the same vehicle as you with 92,000 miles...I purchased last year
with 82,00 miles and do not know if the belt has ever been changed...Have taken
a extensive close look at the belt and see no signs of wear and agree with you on the Service Manual stating change due at 105,000..This tells me that Volvo is certain
it should last at least to that mileage., although who really knows....My extended
warranty which I purchased goes out at 106,000 miles or August next year....
I'am going to hold off replacing mine until at that mileage or next year, which ever comes first...If it breaks prior to then, I'll have the warranty to back me up....
Guess its an individual call...Good Luck
KEN S80 T6
post Sep 19 2007, 05:33 PM
I'm with you, I'm warranted until 100,000 miles and will change it then. I'd better check my warranty- certified preowned. Don't like to see recomendations different than the scheduled maintenance.
Thanks for the reply...
No New Posts Timing Belt Change And Oil Leak
Close to the timing belt cover it is a oil leak
0 Rudy-Dario 317 14th July 2016 - 02:54 PM
Last post by: Rudy-Dario
No New Posts Belt Routing Help!
1 piros365 291 11th July 2016 - 05:54 PM
No New Posts Timing Belts
XC-70
1 dum dums 262 2nd June 2016 - 07:38 AM
Last post by: Vermont
No New Posts Timing Belt Precautions!
Timing Belt Precautions!!
6 qingqin 1,684 29th April 2016 - 12:48 PM
Last post by: Phixion
No New Posts Timing Belt Replacement
4 mike3657 534 4th March 2016 - 04:08 AM
Last post by: derekbrian
Time is now: 29th May 2017 - 01:49 PM
