> A/c Fan Position 4 Problems
Pags
post Aug 18 2007, 03:23 PM
Drives: XC70
Okay, so I can't seem to find any topics on this, I know it's been discussed so if anyone has a link or doesn't mind re-hashing I'm much appreciative.
My fan speed position #4 is NOT working. #1-3 are fine, but when I switch it to 4, the fan shuts off. A/C and heat are working (blows cold) I ran down to the volvo graveyard and pulled a new switch out of another car and the put it in and still no luck. I don't think the resistor is the issue because the switch positions 1-3 are fine. Oh ya, checked the fuse and that's fine too. What else am I forgetting??
Pags
post Aug 21 2007, 11:24 AM
Drives: XC70
Wow, maybe this isn't as common as I thought. I've been looking around and I've seen some information on a possible relay. Does anyone know if the blower fan uses this and where it's located?
Thanks in advance!
post Aug 22 2007, 04:53 AM
Sorry I cant help you on this.
But the radiator fan relay is just above the radiator.
Not sure about the blower fan relay though.
post Aug 23 2007, 04:06 PM
Look for the fuse box under the hood at the base of the windshield. it should be on the drivers side. press the button and open the cover. if you read the cover, it will tell you which fuse to look for. the #4 fan speed setting has its own fuse. check the fuse. it is the easiest thing to do first. hope this helps. sorry, didn't read the whole thing, bone head alert. sorry everybody.
post Aug 24 2007, 04:54 AM
Greekmason,
Thanks. Its a lesson for me too.
Pags
post Aug 24 2007, 10:13 AM
Drives: XC70
No problem! I do the same often...
Anyway, I've been asking around and I hear that there is also a blower fan relay underneath the glove box somewhere. Looks like I'll be tearing that apart this weekend. Fun.
Another mechanic at an independant volvo shop told me that the blower fan itself might be bad. I don't understand how lower speeds could work but not the high one if it were the fan. He had no explanation, just said that it happens. Regardless I won't be going back to that shop for advice any time soon and further more, I replaced the blower fan last year and I seriously doubt that's the problem.
Thanks for the advice! I'll keep posted on what happens... If it hasn't happened yet to anyone here, I'm sure it will eventually!
ra7850
post Aug 29 2007, 08:38 PM
Drives: 97 850
97 Volvo 850 Non ECC, non turbo.
I have a similar issue, except the first 3 settings don't work unless the car is moving. I checked both of the position fuses, both are good. Anybody have any other suggestions? The A/C relay will be changed next I guess. The odd thing is
when the vehicle is stopped there is no air flow out of the first 3 speed positions, the only air flows on the 4th position while motionless. It air flows on the first three while moving but the output appears to be less then before the issues occured.
More updated information, Both of the relays behind the glovebox on the blower itself are the same, they are green relays volvo part number 94994787. The relay on the left (1) can be removed and the blower still runs. I swapped left to right and still no air with the first 3 positions, the 4th position still works. So the relays are both functioning. The relay on the right (2) must be in or it doesnt work at all.
What else can I check, any other thoughts?
Thanks in advance...
Robert
post Sep 4 2007, 02:27 AM
QUOTE(ra7850 @ Aug 30 2007, 09:38 AM)
I have a similar issue, except the first 3 settings don't work ...
[right][snapback]61719[/snapback][/right]
Usually, this refers to problems with the SWITCH itself.
ra7850
post Sep 4 2007, 10:19 AM
Drives: 97 850
Thanks, I was planning on trying to change that out this afternoon. I'll post results once it's been replaced.
Robert
Pags
post Sep 9 2007, 01:03 PM
Drives: XC70
You also might want to replace the blower motor resistor. Usually when the fan is not working on positions 1-3, it's the resistor. It may feel like the fan is working just from the air coming through the system due to the motion of the car. It could also be a bad blower fan motor. I had these problems and I just replaced both the fan motor and resistor since they are in the same place below the glove box compartment.
daveppeters
post Sep 26 2008, 05:31 AM
Drives: 1993 Volvo 440 SE, 1994 Volvo 850 GLT Estate
QUOTE
I have the exact same problem. Did you figure out exactly what it was? Was it the fan resistor or blower motor?
post Oct 5 2008, 11:15 PM
Even If you want to try the easy ones first, it'd still be the trim-switch / resistor.
Cheers.
No New Posts Fan Blower Random Speed
1 silverunner 21 21st November 2008 - 06:44 PM
Last post by: silverunner
No New Posts Ac Vents Closing As Car Accelerates
3 ScruffeeBear 67 31st October 2008 - 05:01 AM
Last post by: The Doctor
No New Posts Accelerator Pedal Vanished, Re-appeared
A one-time loss of gas pedal response
6 elmwoodblues 111 30th October 2008 - 09:51 PM
Last post by: checksix
No New Posts Acc Dual Zone
One zone is warmer than the other
4 Mushahidi 50 28th October 2008 - 05:23 AM
No New Posts Fantastic Link From Volvo Forums Uk
buy this guy a pint!
0 honkinmax 105 23rd October 2008 - 10:21 AM
Last post by: honkinmax
Time is now: 1st December 2008 - 07:33 PM
