> S60 Check Engine Light Reset
Tropicalcats
post May 28 2007, 06:30 PM
Drives: 1996 850 Wagon, 2003 S 60
I have a 03 S-60 and need to know how to reset the "Check Engine" Anybody Know how?
manlystanley
post May 28 2007, 06:51 PM
Drives: 1998 S90
Get a ODB2 handhold. You can see the codes and reset the light as well.
Best Regards,
Stan
Tropicalcats
post May 28 2007, 07:01 PM
QUOTE(Tropicalcats @ May 28 2007, 07:30 PM)
[right][snapback]56869[/snapback][/right]
Don't mean to sound stupid but what's a ODB2 handhold?
cordoba
post May 28 2007, 10:20 PM
Drives: S60 2.4T
QUOTE(Tropicalcats @ May 28 2007, 06:30 PM)
Tropicalcats, if you have a check engine light then chances are there is a problem that needs to be fixed. Resetting the light won't help much if the problem still exists...the light will come back on.
If you have a service reminder light on, that can be reset easily.
A handheld OBD II scanner will read the trouble codes from the computer and allow you to clear the codes.
flyjets2
post Aug 16 2009, 04:07 PM
Drives: 2004 S60 / 2005 XC 90 T6
Verify that the following recall was accomplished by a "reputable" dealer:
Build Years/Makes/Models:
2003 - 2004 VOLVO S60
2003 - 2004 VOLVO V70
Units affected:
38700
Recall Number:
07V226000
Summary:
ON CERTAIN PASSENGER VEHICLES, THE FUEL PRESSURE SENSOR LOCATED ON THE LEFT END OF THE FUEL RAIL MAY, AT TIMES, TRANSMIT INCORRECT SIGNAL REGARDING THE FUEL PRESSURE TO THE ENGINE CONTROL MODULE. IF THE SIGNAL IS OUTSIDE OF THE PRE-PROGRAMMED ALLOWABLE LIMITS, A DIAGNOSTIC TROUBLE CODE MAY BE SET AND THE CHECK ENGINE LIGHT WILL COME ON. THE SOLDERED JOINTS ON THE CIRCUIT BOARD OF THE FUEL PRESSURE SENSOR MAY CRACK DUE TO TEMPERATURE CHANGES AND EXCESSIVE VIBRATIONS.
Consequence:
MISFIRE MAY OCCUR DURING DRIVING THAT, IN TURN, WILL REDUCE THE ENGINE TORQUE AND IN THE WORST CASE SCENARIO, THE ENGINE MAY STALL WITHOUT WARNING. IN CERTAIN TRAFFIC SITUATIONS THIS COULD CAUSE AN UNSAFE SITUATION AND POSSIBLY A CRASH.
Remedy:
DEALERS WILL REPLACE THE FUEL PRESSURE SENSOR FREE OF CHARGE. THE RECALL BEGAN ON JUNE 29, 2007. OWNERS MAY CONTACT VOLVO AT 1-800-458-1552.
Notes:
VOLVO RECALL NO.R181.CUSTOMERS MAY CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION?S VEHICLE SAFETY HOTLINE AT 1-888-327-4236 (TTY: 1-800-424-9153); OR GO TO HTTP://WWW.SAFERCAR.GOV.
Doogwhan
post Aug 28 2009, 11:13 PM
Drives: 2004 S60R, 1992 Volvo 245, 2003 VW Jetta TDI (The Bride's)
Here's a simple fix:
1. Go to Autozone.
2. tell them that your "check Engine" light is on, and ask them to pull the code(s) from you car, and reset the light.
3. Wait patiently as the Autozoner does this for free.
4. Write down the code(s)
5. Go home and Google the code(s),(should be a P0xxxx format)
6. Post back here whatever you found out.
7. Watch in horror as we try to help.
Hopefully it's as simple as an Evaporative Emissions code or something benign.
Are there any other issues that we should know about?
1 namz 251 21st August 2016 - 03:09 AM
No New Posts Check Engine Light Reset - No Powertrain Dtc's
5 idainc 364 12th August 2016 - 07:37 PM
Last post by: idainc
No New Posts Reset Car So It Will Start
passenger side air bag curtain deployed
0 docwho4 221 8th June 2016 - 03:59 PM
Last post by: docwho4
Engine Swap question
0 rax_tempus 299 20th May 2016 - 09:57 PM
Last post by: rax_tempus
No New Posts Engine Threw A Rod
Help Needed
0 Justin Bert 1,296 1st May 2016 - 06:51 PM
Last post by: Justin Bert
Time is now: 26th February 2017 - 11:29 PM
