> 60. 000 Mile Maintenance - Cost And Things Done
jackstone
post Feb 27 2007, 10:46 AM
Drives: 2002 Volvo S60 AWD
I have my 60,000 mile regular maintenance coming up for my 2002 S60. I'm wondering if you can give me a fair assessment of A. the work that a mechanic is likely to accomplish and B. a reasonable cost estimate so I can make sure I'm not getting ripped off.
I would like to know what is generally done but I have some details I can also provide that may make it clearer for what they will do to my car.
I had the tires replaced at around 50,000 miles. I had a fairly bad incident in the snow this past December which required my having to replace the transmission (cost around $5000)... I also had an engine pump leak that I repaired last August at a cost of $400ish.
I haven't been pleased with some of these uncommon expenses I have experiences with what are usually good quality cars. I think I have been unlucky bc my car has been in 3 starkly different climates in the past year (Pennsylvania, then Missippi, then Colorado).
Thanks in advance.
BiancaNeve
post Feb 27 2007, 11:35 AM
Drives: 2003 Volvo S60 2.4L Manual
The 60K service is, in my opinion, a complete waste of time. What you can do is ask the dealer for a write up of the things that are done. Generally, they have these pamphlets that will let you know. I believe the dealer charges $799 or $699 for the work.
If you read the list, you'll be upset. They "test the windshield wipers," (I believe you can do that one yourself) and "road test the car" (which is something you do EVERY DAY if you drive it!), they change the oil, change the air filter (which is a $20 part that you can easily do yourself), and do a rough inspection of the vehicle. I don't think they even change the cabin air filter which is a simple procedure also.
I used the list and checked off every thing on it, it took me about half of the day and cost me about $400 less.
bld444
post Feb 27 2007, 08:06 PM
Drives: 2005 S60R
"Complete waste of time" is the biggest factory service your car will ever receive.
60k Service for the S60:
Replace
Oil & Filter Change
Air Cleaner Filter Change
Replace Spark Plugs
Replace pollen Filter
Lubricate
Power antenna
Trunk/hood, hinges and latches
Inspect
Automatic transmission fluid
Engine drive belt (accessory belt)
PCV nipple (orifice)/hoses, clean
Battery (check charge and electrolyte level)
Inspect brake pads, replace components as necessary
Brake fluid level2 - check
Tires3, check pressure, wear and condition
Power steering fluid level
Check your owners info on volvocars.us, there's some other things as well.
BiancaNeve
post Feb 28 2007, 06:24 PM
Oh don't get me wrong! All of that service is important! However, it can be done for considerably less than $700!
Panoply-II
post Mar 1 2007, 08:32 AM
It seems like different shops have different lists. From memory, mine included cabin filter change and parking brake adjustment (which was needed). I don't remember the cost. DIY saves $ but not time. Personally, I like hitting the suggested maintenances and add that in to the cost of ownership.
Not like the old days when I could find enough room to get a hand down in the motor.
PAVOLVO
post Apr 26 2007, 03:31 PM
Drives: 05 XC90 AWD
Most of the 10K services are a complete waste of money. You can do most of them yourself.
Max Volvo
post Apr 29 2007, 11:58 AM
Drives: 2002 S60
QUOTE(bld444 @ Feb 27 2007, 06:06 PM)
Replace
Oil & Filter Change
Replace Spark Plugs
Lubricate
Power antenna
Inspect
[right][snapback]51933[/snapback][/right]
Sometimes I have difficulty with extracting a writer's meaning. bdl444 did you mean that the 60k service is a waste of time, or it is not a waste?
If your list is a complete list of what a owner will receive in exchange for forking over $600 - then it is a waste of money.
But if replacing brake pads, or other brake 'components' is included in the cost, then it's a bit more accceptable.
I've read that some folks recommend dealer service for the s60 because they'll lube the 'sub-chassis." Is that ture? What does that job entail? Can it be DIY?
Pentheos
post May 1 2007, 01:44 PM
Drives: 2002 S60
I just dropped my 2002 S60 off for its 60,000 mile service at my local independent mechanic.
Besides looking things over and lubing the car up, they will:
Change oil + filter
Change engine air filter
Change cabin filter
Change spark plugs
Flush/fill coolant
Flush/fill brake fluid
Rotate tires
All for about $450.
(NB: I changed the filters myself, and this dropped the price to $360. I'll work on top of the car, but not below it).
gouimet01
post Jul 27 2007, 11:26 AM
Drives: 2003 Volvo S60 2.5 AWD
I fell for the $850 60K service -- plugs, wires, radiator flush, oil change, rotate tires, filters, inspect this and that, top off fluids, grease this and that. Regretted not asking more questions and thinking about taking it somewhere else or doing a lot of it myself. BTW - dealer recommended I do all this stuff at 40K miles and I declined. What a racket. :blush:
George
0 HRPOWER 325 19th October 2016 - 06:22 PM
Last post by: HRPOWER
No New Posts Cost Of A New Key Fob?
2007 Volvo S40 T5 AWD
8 dobrovod 42,816 21st March 2016 - 04:24 AM
Last post by: eddie smith
No New Posts Cost Of Timing Belt Replacement
Cost
3 tennisist 4,316 26th August 2012 - 06:47 AM
Last post by: Vermont
No New Posts Android Integration For Your Volvo Xc90
1 GROM Audio 2,537 24th May 2012 - 02:30 PM
Last post by: GROM Audio
No New Posts Android Integration To Your Volvo Stereo Is Here!
0 GROM Audio 7,698 10th April 2012 - 05:43 PM
Time is now: 24th April 2017 - 10:07 AM
