> Dash Removal For Mounting Tab Repair.
post Dec 2 2006, 10:36 AM
First thing you have to do is disconnect the battery.
Next start off by removing the wiper arms.There is a 13mm nut per arm.You may need to remove a black cover to get to the nut.
Then remove the 4 Torxes 25 screws holding the plastic cover under the the wiper arms.You will have to also remove the 2 clamps holding the rubber hoses to the plastic cover.Lift up on the front of the cover then slide it towards the front of the car to remove it.
Then under there is Either 4 torxes 30 screws or 10mm screws that hold the dash to the body of the car.Be very careful removing and tightening the screws for the dash.The dash tabs could break and then will need to be repaired or the dash will need to be replaced.Also just pull up on the pollen filter case if it has one.If not just remove the ring that is there.
Going to the inside of the car you will need:T-25 socket or bit with a screwdriver,A long T-30 socket,18mm socket with extension and ratchet,wire cutters,T-15,T-20,10mm ,12mm,13mm,1/4 drive socket.
First start off by removing the center console.If it is a 850 remove the front cubby by reoving the 2 T-25 screws then under the cover is 2 T-15 screws remove them.Unplug the black and grey plugs in the hole by the 2 T-15 screws.Then lift up the armrest and remove the black cover and remove the 2 8mm or 10mm screws.The early 850's may have T-25 screws.
The S70 remove the shifter boot cover bye pulling it towards the drivers seat with the arm rest up.Then remove the cover in the cover under the arm rest.Remove the 2 screws in there.
Unplug the 2 plugs behind the cover for the E-brake.Lift the back of the center console up first and work it out.
Next remove the radio by pushing in the little tabs on the side of the radio then they will pop out and then pull them to release the tabs all the way.Remove and unplug the radio.
The next step will depend whether you have ECC (Electronic climate control)or MCC(manual climate control)
If you have ecc then you car reach through the hole for the radio and push the climate control module from the back.Be careful put a rag on your arm.Sometimes it is stubborn and when it releases it will cut your arm.
If you have MCC then remove all 3 of the control knobs.Then under the 2 outer knobs is 2 T-25 screws.Remove them then push the outside cover out from the back and unplug the wiring.On the sides you will see one Phillips screw on each side remove them.You are done here for now.
Next remove the air bag from the steering wheel.Turn the steering wheel so that the top is to one side.There is a hole in the back of the steering wheel.Insert a long T-30 and remove the screws for the airbag.Always remove and tighten the right side screw for the air bag first.If not then the horn might not work.Next take the little T-20 screw stored in the steering wheel.That will get screwed into the hole on top of where the bolt for the steering wheel is.It will hold the Contact reel from unrolling.
Note: Break the bolt for the steering wheel loose before installing the small screw.
Remove the bolt holding the steering wheel in.It is a 18mm head bolt.Then lift the steering wheel off.
Next remove the steering column covers.On the S70 pull up on the top one and remove it.Then loosen and remove the T-25 screws in the bottom cover.The screws go from the bottom going up.
The 850 you will have to remove 2 T-15 screws in the front part of the cover.You will need it to be long to reach the screws.That will remove the top cover.Note be careful removing the T-15 screws.Hold down on the top cover while removing then or the tabs might break off the top cover.Then remove the 2 T-25 screws and remove the lower cover.
Next remove the turn signal switch and the wiper switch.They are held on by 2 T-25 screws each.Next remove the SRS contact reel.Note:Be very careful the plastic is very brittle.
There is 3 screws total holding it in.Then unplug it and remove it all the way.
Next remove the lower dash panel on the left side of the car.Then look up under the dash and you should see a long red plug or a Yellow with a Purple pull tab to release. It should have a tab to pull to release it.Pull it and release it.That is the main plug for the dash.
Next on the 850 you will have to remove the metal knee bolsters.There is 13mm nuts holding it in.Note:Or you can wait till you remove the dash.It is easier to remove them once the dash is out.Pull back the cover at the bottom of the dash by the door.The sill cover that runs all the way back.Pull it off by the dash.You will see a screw holding the bottom of the dash.remove the 10mm screw.
Then go to the other side and remove the glove box assembly.Remove the T-25 screws folding it in.On the 850's unhook the glove box support arms by inserting a small screw driver in the hole.Then remove the insert.Next remove the lower dash cover on that side as well.
Also unplug the passenger side Air bag.You will see the plug.Look for an orange wrapped wire and follow to the plug.Then pull back on the sill cover again and remove the 10mm screw on that side as well.
The dash should be ready to come out.Make sure you have someone help you remove it.
You will need to leave the key out of the ignition.To get the car out of park.Look on the right side of the shifter.There is a soleniod you will need to push the soleniod back and push the button on the shifter and pull out of part.
Remove the dash.If it is turbo you will also have to unplug the line for the boost guage if the car has one.Also be careful some cars have an extra plug you will have to unplug while removing the dash.Watch while removing.
Set the dash off to the side in a safe place.
Then you will see the Dash Mounting Tabs on the back of the Dash.
This is what I would use to repair the Tabs. They call it Piping strap.I have a picture posted at the bottom of the post.
What you will do is cut a piece that will go up and over the tab that you can screw on each side. You will need to screw it over the clips that are there with the threads.Make sure you get it as tight as you can. Then when you got them all secured before installing make sure you install either a piece of Duct tape or Felt tape over the Tab and strap. This way you know it won't squeek or anything like that.
Then reinstall the dash.
post Dec 7 2006, 12:35 AM
Hey, nice one in the dash repair.
The 850 dashes are quite nasty for squeaking! While mine has not squeaked yet, I suppose it would be better for me to prepare for the (inevitably coming) rainy day.
Hehehe.
Piping Strap, eh?
:thumbsup:
post Dec 7 2006, 07:44 PM
Yes Piping strap thats what they call it here.
That works the best that I have found.
bigdaddy
post May 8 2008, 10:11 AM
Drives: 1996 850 T5
:clap:
good one, this. exactly what i've been looking for.
The outmost left and right screws on my firewall which are holding the dashboard is very very loose.
I really should try this out.
post May 8 2008, 10:19 PM
Bang,
For yours, we really have to spend some time lah. I'm not satisfied with the work we did on the dashboard frame the last time. Find some free time, and come down here again, and let's spend the whole morning on yours alone. That day's DIY was with a few other cars, so can concentrate fully.
bigdaddy
post May 8 2008, 11:11 PM
Drives: 1996 850 T5
Bro, you are right. I wasn't satisfied with it myself. It was ok initially. I think we need to take outthe whole dashboard and work on the mounting tabs. Currently my dash board is being held by the 2 middle screws onthe firewall only. The outer left and right ones are very loose.
I also found a god specimen of a tailgate panel at Sabri's which still has all the mountings, but no clips. Where can we get the clips?
Am now also recognizing new sounds from teh back part of the car. Driving me nuts!
I'll be aorund often, especially during teh Wesak weekend. That weekend sounds good to you? If we don't want to do it in Kg. Dusun Nyior, my house there has big space too.
I owe you a lot for teaching me these DIY stuff, my Bear bro! :thumbsup:
post May 9 2008, 05:07 AM
Dont worry, dude.
When i'm THAT desperate, you can write me that big FAT cheque.
HAHAHAHAHA...
:haha:
OK,OK, seriously, i think the Wesak weekend, i'll still be around, yes. Wife didnt say anything about going nowhere. And am not going to volunteer any destination, either. HEE HEEE... I know, I'm bad.
We can start looking for the clips, and i will try to source for some acetones, to melt the ABS plastics with. Combined, we can mould the mounting tab back again. That should last a few years, without fail, if done right.
Will see about that later.
bigdaddy
post May 10 2008, 01:33 AM
Drives: 1996 850 T5
Thank bear... will get in touch with you a few days before the weekend to iron things out.
post Feb 28 2009, 11:37 PM
Here is a few more pics of how I put the piping strap.
(IMG:http://img.photobucket.com/albums/v624/mustang8719/Picture154.jpg)
(IMG:http://img.photobucket.com/albums/v624/mustang8719/Picture156.jpg)
post Mar 3 2009, 10:14 AM
Thanks for the pics, Tech!
post Mar 3 2009, 08:53 PM
Your welcome
bigdaddy
post May 28 2009, 08:56 AM
Drives: 1996 850 T5
Bear, are you up to help/instruct me to do this on my ride? (IMG:style_emoticons/default/smile.gif) I'll rde up o Seremban for the weekend just to get it done with you!
post May 29 2009, 12:58 AM
Dude, that's easy lah. Basically there is no change from what we discussed long ago.
In anycase, this weekend is no good. Am still in the hospital right now.
Have to find some other time.
owenmpk
post Nov 26 2009, 10:42 PM
Hello Gang,
I am helping my daughter replace the dash in her 850 with one from wrecked 850. We have the dash removed (great instructions by the way but we cannot figure out how to fully remove the dash pad. We have something hanging it up by the airbag but I cannot see what it is. Any ideas?
post Nov 28 2009, 01:57 PM
Unfortunately, i do not have the navigator airbag to make a comparison with. But if you want to just remove the TOP part of the dash, it should be able to be lifted upwards.
Have you unscrewed those at the aircond/heater duct holes?
owenmpk
post Nov 30 2009, 10:52 AM
QUOTE (ampangbear @ Nov 28 2009, 02:57 PM)
Yes I have and the screws at the top of the glove box.
No New Posts For Sale: 1993 Volvo 240 Classic Wagon
0 penbeatssword 26 26th August 2010 - 08:32 PM
Last post by: penbeatssword
No new Topic has attachmentsDashboard Problems
Dashboard Problems
56 darrendaly 19,459 22nd August 2010 - 10:35 AM
Last post by: birdog
No New Posts Forbes Highest-paid
Celebrity CHEFS...
8 ampangbear 235 12th August 2010 - 09:34 PM
Last post by: Royce
No New Posts Dash Guages And Lights Went Crazy
1998 S40 Dash Problems
0 Kat 43 25th July 2010 - 11:35 AM
Last post by: Kat
No New Posts Dash Lights
dash lights out
1 kiakid2007 95 26th June 2010 - 10:52 PM
Last post by: SeaMike
Time is now: 2nd September 2010 - 05:38 PM
