> Volvo S60 Awd Clicking Noise In Passenger Door, electrical problem?
begler
post Oct 26 2006, 04:22 PM
Drives: 2002 Volvo S60 AWD
I have a 2002 volvo s60 AWD and recently I noticed a clicking noise in the passenger door. It would only occur during the first five minutes of driving, then it would go away. Now it is more like 15 mins and more rapid but eventually it goes away. While the clicking occurs, the power window, power mirror, locks on that door are inoperable. Everything else in the car is ok. When the noise stops, everything on the door works fine. Is it a relay problem? Is it something I can fix or should I go to the dealer?
volvo_kris
post Oct 27 2006, 05:00 AM
Drives: V70
Hi, there is a passenger door module that controls the window & locks. The module has relays inside which click on/off when they get power. It maybe that you have a poor power connection to the module.
Gogigboy
post Oct 27 2006, 06:39 AM
Drives: Volvo S60 SE D5
I have the same car but not AWD, I've got the same problem, I think its when the weather is cold, it was clicking for 15 minutes this morning, it was 8 c outside.
I put a message on here last week and just seen the reply, I will try later, I hope it is of some use to you.
you could try the infamous UEM reset which has already been posted on the same forum...
- Close all of the doors and bonnet.
- Key in position II engine not running.
- Hold both the driver window and passenger window switches in the driver door panel in the closed or up position for 5 to 8 seconds after the windows are closed.
- Release buttons.
- Remove the ignition key.
- Operated the remote twice. lock/unlock lock/unlock.
This will reset the UEM brain. This can correct faulty operation of the sunroof and/or erratic door lock function.
its worked well for a few people..
begler
post Oct 27 2006, 09:58 PM
How can I access the passenger door module easily? Or should I leave it to the dealers? If it's a matter of a few screws, I can look at it but I don't want to potentially damage the door upholstery. Is it something where you need some special tools? (BTW, I tried the UEM reset to no avail. )
begler
post Oct 31 2006, 10:01 AM
OK, the plot thickens. The problem only occurs when the temperature drops below 68 degrees F. When the temperature rises above, everything is OK. In fact, if I leave the car out in the sunshine, when I start the car there is no clicking and everything works. When I start the car in the morning when it is cooler, the clicking will persist. And get this, when the temperature is below 68 degrees F, the dashboard displays dashes instead of the temperature i.e. --F . When the temperature reaches 68F it displays 68F and so on for above temperatures. So the temperature gauge is included in this situation somehow. Any ideas now? Weird stuff.
Gogigboy
post Oct 31 2006, 10:48 AM
Obvioulsy a common fault.
To access the module, pop the plastic off the door handle and find two screws (Hex) then you will finda around the panel round plastic clips. Push the centre of them with a screwdriver until they pop in then the panel should lift off. When replacing the panel, make sure the centre of the clips a sticking outwards, push them through the panel into the whole then push the centre of the clips in and they should lock.
sl33stak
post Jan 19 2009, 08:21 PM
Drives: 2001 S60
QUOTE (begler @ Oct 31 2006, 10:01 AM)
I have the EXACT SAME PROBLEM in my wifes 2001 S60!!!! Once the we run the car (for almost an hour in the winter) the clicking stops. But until then, no control over passenger side window,lock,or interior map lights, or moonroof. Our temperature display also reads --- until the clicking stops.
Did the UEM reset work for you?
begler
post Feb 3 2009, 08:25 PM
QUOTE (sl33stak @ Jan 19 2009, 08:21 PM)
No it did not. I had to get the faulty electrical relay in the door replaced. Cost $100 at the dealer. Sorry about that.
Desolator
post Nov 2 2012, 12:13 AM
Drives: Volvo S70
QUOTE (begler @ Feb 3 2009, 09:25 PM)
Hi
do you mind telling me what relay , there are no relays in the driver door.
No New Posts Volvo S40 2005 Piston Issue
2 volvos40ireland 17 Yesterday, 08:33 PM
Last post by: Platypup
No New Posts Instrument Panel Bulbs
I'm having trouble finding access to them
1 Julie Allen 32 15th March 2017 - 08:30 PM
No New Posts Volvo Vip Protection Plans Worth It?
0 DJC 51 6th March 2017 - 04:28 PM
Last post by: DJC
Oil leak in the Turbo pipes
0 Nazih Mihamed 55 18th February 2017 - 02:40 PM
Last post by: Nazih Mihamed
No New Posts Topic has attachmentsIntroduction
2 scdambrosio 61 14th February 2017 - 04:34 AM
Last post by: Wojo1974e
Time is now: 28th March 2017 - 04:35 PM
