> Low Beam Headlighht Bulb, Replacing bulb
deadfan50
post Feb 8 2012, 05:28 AM
Member
Drives: 2001 V70XC 1992 240 wagon
The drivers side low beam headlight on my wife's 2007 V70 went out yesterday. Does anyone know a trick to replacing this bulb. I'm fairly handy, but with everything in there I can't even get to it. Thanks
grendel1960
post Feb 8 2012, 09:25 AM
Veteran
Drives: 92 volvo 440, 91 volvo 940
I did my 850 the other week and its a tight squeeze and almost impossible to see what you are doing, theres one wire clip that has to be unclipped to get the bulb out, I seem to just fumble around until it unclips, then spend 10 minutes trying to clip it back in again.a small dentists type mirror might help you see what you are doing, but its tight.
the plastic cover is a part twist to release.
Grendel
post Feb 8 2012, 08:35 PM
Senior Veteran
QUOTE (deadfan50 @ Feb 8 2012, 05:28 AM)
check the fuse box first, if ok then change both bulbs,or your bulb failure relay light will come on.
FLVolvo04
post Nov 21 2012, 04:32 PM
Drives: 2004 Volvo V70 Wagon
I did our 2004 V70 and yes it was tight on the driver's side but using a small mirror on the end of an extendable rod helped enormously. The information on this forum was also invaluable in tackling this task. You have to remove and replace the bulb blindly but if you work slowly and using just your finger tips it can be done. The biggest part is patience. Lots of patience will pay off. When removing the wire clip from the bulb be gentle. When I went to do the passenger side, which is enormously easier, the light clip fell apart. It is plastic and the age and heat just makes the cheap plastic crumble. Needless to say I stopped before I created a real problem. Now I have to go get a new wire for the passenger side before I can install the new bulb. So far with only one new bulb in place I haven't had any warnings. Good Luck.
« Next Oldest 2G (2001-2007) V70, V70XC & XC70 Forum Next Newest »
No New Posts Lowering Springs
Which brand is lowest
0 Snabblåda 93 24th July 2014 - 09:39 PM
Last post by: Snabblåda
No New Posts Lowering Springs Australia
0 TylerFunnell 245 20th February 2014 - 09:23 PM
Last post by: TylerFunnell
No New Posts Lower Control Arm Bush Different
2 danormal 352 18th October 2013 - 02:55 AM
Last post by: danormal
No New Posts Low Torque, Bad Accel..
After the 95000km service it got really slow...
2 S80Newbie Owner 502 12th July 2013 - 08:25 PM
Last post by: S80Newbie Owner
No New Posts Low Rpm Misfire
1 Mr740@106 757 30th December 2012 - 06:59 PM
Last post by: danielm85948
Time is now: 1st October 2014 - 12:57 AM
