> Side Mirror Adjustment Not Working, Electric side mirror issue
beauie
post Oct 2 2011, 05:23 AM
Drives: 2003 XC90
The electric side mirror adjustment, L&R, (drivers side door armrest near window adjustment buttons) on my 2003 XC90 is not working. All other electrics are ok. Cannot seem to see a fuse for this circuit in the fuse box under the bonnet. Suggestions? Is there another fuse box perhaps?
Thanks for any suggestions.
Best,
ChrisG56
post Oct 13 2011, 08:11 PM
Drives: 2007 Volvo XC90 AWD 3.2
Wish I had an answer but I dont - I do however have the same problem on my 2007 XC90... everything was just fine but all of a sudden both mirrors have stopped folding or moving... no lights on the little buttons when i press them...and the mirrors are sorta floppy... free to move in or out by hand they flop in slightly as I drive due to wind... all help/advice greatly appreciated
OK so immediately after I wrote the above I found the user manual (which I do not have) online - see link below
http://new.volvocars.com/ownersdocs/2007/2...90_09.htm#pg201
On the second fuse panel... to the left hand side of the dash (you need to pop the little hemispherical panel off) I removed fuses 5 and 6 for the power mirrors then fuse 12 for the upper ecm in that order. I turned on the ignition (dont know if this makes a difference) then turned it off again. I then replaced the fuses in the reverse order... whoopee... full functionality returned to the mirrors... moving and folding... good luck !!
(IMG:style_emoticons/default/grin.gif) (IMG:style_emoticons/default/thumbsup.gif) (IMG:style_emoticons/default/grin.gif) (IMG:style_emoticons/default/thumbsup.gif) (IMG:style_emoticons/default/grin.gif)
bjoroy
post Dec 7 2012, 02:08 AM
Drives: 2003 XC90 D5 AWD
This trick actually works! Same problem on my 2003. Removed 5, 6 and 12, ignition on, replace 12, 6, 5 and the mirrors starts working again :-) if you on the other hand place the 12-fuse in the 13-slot (which is a spare slot) you'll have a short moment of panic before you realize your mistake (IMG:style_emoticons/default/tongue.gif)
timboconqueso
post Jul 13 2015, 03:26 AM
Drives: 2013 XC90
Hello everyone. Just wanted to let you know that I also had this problem this morning on my 2013 XC90. But slightly different symptoms and results.
* after a hard rain last night, when I started up the car this morning the automatic mirrors would not come back out from a stowed position
* all attempts to restart the car, turn random buttons off on the same panel did not fix the problem.
* all other electronics worked fine.
* fearing I would damage the mirrors, I put slight pressure on them to manually push them out but there was too much resistance so I just left them stowed.
* I drove to work with stowed mirrors (hyper vigilantly)
* I researched the problem and found this forum post. Planned to try the fuse trick after work.
* After work, went to the car, started it up... decided to test the mirrors first.
* mirrors worked fine. I didn't do anything differently.
I can only assume this is related to water, as the weather had cleared up and the mirrors had dried up by that point.
timboconqueso
post Jul 15 2015, 05:20 AM
Drives: 2013 XC90
Update: today it did it again. Only this time there was no rain at all. Hot humid day. I pulled the fuses out and tried this trick several times with no success. I came back a short while later and turned the car on and just pushed the button. This time the drivers side mirror unfolded but the passenger one did not. I pushed the button again and the drivers side folded. I pushed it a third time and both came out.
When I arrived home I pulled all three fuses (5,6,12) and tested them with a multimeter. I noticed on one of the 25amp fuses, the connection was poor. Closer inspection revealed a slight film covering the leads of the fuses. I cleaned the tips of them off with a dry Brillo pad (being careful not to damage the soft metal of the leads) and tested them with the multimeter again. This time, I had perfect connectivity.
I put the fuses back in with the ignition turned off and heard a clunk sound in the door. Powered on the ignition and the mirrors work fine. I will keep monitoring and update appropriately. But if you never hear from me again, it's likely the cleaning of the fuse tips fixed my problem.
CT Volvo Guy
post Oct 11 2015, 05:52 PM
Drives: 2010 Volvo XC90
Finally! The answer I was looking for.
To be specific, the side mirror / mirrors on my 2010 Volvo XC90 stopped working / were not working after my wife took our car in to get washed. I think there was too much polish on the driver side door which caused the panel to short out. In any case, removing fuses 5, 6, and 12, cycling the key in the ignition switch, and replacing the fuses did the trick. I also used a multimeter to test the fuses no degradation noted. I did note fuse 12 (10 amp) fuse did have some oxidation on one prong of the fuse. I used some 240 grit sand paper to clean up all the fuses but I don't think this would have been necessary. I think pulling the fuses and cycling the ignition was all that was needed. Also, I didn't pull them out or replace them in a particular order.
I also had the same problem where the driver's side mirror was "flopping" and was not engaged. After removing and replacing the fuses to restore the side mirror control functionality, I cycled the mirrors to the stowed (folded in) position and back out. That fixed the floppy driver side mirror issue.
Thanks to everyone for saving me time and money having to deal with the dealership.
[I added a lot of extra words to make it easier for the next person to find with Google!]
« Next Oldest Volvo XC90 Forum Next Newest »
3 User(s) are reading this topic (3 Guests and 0 Anonymous Users)
No New Posts Not Starting After Heavy Rain
0 cooltony91 476 1st July 2015 - 09:14 PM
Last post by: cooltony91
0 cooltony91 317 1st July 2015 - 08:09 PM
No New Posts Not Start Without Any Messages.
0 Kikyoung 1,301 20th April 2014 - 02:36 AM
Last post by: Kikyoung
No New Posts Topic has attachmentsNot All Oil Filters Are Created Equal
Cut Open Filter for a 850
8 SeaMike 1,814 20th January 2014 - 11:31 PM
Last post by: Kiss4aFrog
No New Posts Mirror Light
What does it do?
2 _John_ 865 23rd October 2013 - 08:25 AM
Last post by: _John_
Time is now: 8th February 2016 - 10:16 PM
